Старый 10.09.2012, 23:15   #1
sashanazarov: Figuring out where some table field is modified
Источник: http://sashanazarov.blogspot.com/201...-field-is.html
Sometimes I need to find out where a particular table field is modified in the X++ code. Normally, I call "Used by" form, filter records out by Reference = Write, put manually breakpoints in the corresponding X++ lines and then run the scenario to see which breakpoint is eventually hit.
However, if there are too many cross-references, I don't bother adding breakpoints manually. Instead, I add a button to xRefReferencesUsedByTypedTree form, set its Label property to "Add breakpoint" and MultiSelect to "Yes", and then override its clicked method like this:
void clicked()
container breakpoints;
boolean enable = true;
xRefReferences xRefReferencesLocal;
breakpoints = infolog.breakpoint();
for (xRefReferencesLocal = XRefReferences_ds.getFirst(true) ?
XRefReferences_ds.getFirst(true) : XRefReferences_ds.cursor();
xRefReferencesLocal = XRefReferences_ds.getNext())
if (xRefReferencesLocal.line > 0)
breakpoints += [xRefReferencesLocal.path()];
breakpoints += [xRefReferencesLocal.line];
breakpoints += [enable];
infolog.breakpoint(breakpoints);
Now, after opening "Used by" form, I simply click "Ctrl+A" and then the new "Add breakpoint" button, so all required breakpoints are in place.
axaptapedia: Table Field Group Blog bot DAX Blogs 0 02.07.2011 05:37
axaptapedia: Table Field Group Blog bot DAX Blogs 0 25.06.2011 06:33
Халтура в AX2009: идентификаторы из USR в GLS, GLP и даже SYS-слоях EVGL DAX: Программирование 2 21.02.2011 19:44
DynamicsAxSCM: The InventTrans table. Explore various field usages. Blog bot DAX Blogs 0 09.11.2010 19:10
Часовой пояс GMT +3, время: 16:27.
