#1 |
Malaysia: Building a tree lookup
Источник: http://axmas.blogspot.com/2012/11/bu...ee-lookup.html
============== 1. In the AOT, create a new form named BudgetModelLookup. Set its design properties as follows: Property Value Frame Border WindowType Popup 2. Add a new Tree control to the design, with the following properties: Property Value Name ModelTree 3. Add the following line to the form's class declaration: BudgetModelTree budgetModelTree; 4. Override the form's init() method with the following code: public void init() { FormStringControl callingControl; callingControl = SysTableLookup::getCallerStringControl (this.args()); super(); budgetModelTree = BudgetModelTree::construct(ModelTree, callingControl.text()); budgetModelTree.buildTree(); } 5. Override the mouseDblClick() and mouseUp() methods of the ModelTree control with the following code, respectively: public int mouseDblClick(int _x, int _y, int _button, boolean _ctrl, boolean _shift) { int ret; FormTreeItem formTreeItem; BudgetModel budgetModel; ret = super(_x, _y, _button, _ctrl, _shift); formTreeItem = this.getItem(this.getSelection()); select firstOnly SubModelId from budgetModel where budgetModel.RecId == formTreeItem.data(); element.closeSelect(budgetModel.SubModelId); return ret; } public int mouseUp(int _x, int _y, int _button, boolean _ctrl, boolean _shift) { int ret; ret = super(_x, _y, _button, _ctrl, _shift); return 1; 6. The form should look similar to the following screenshot: 7. In the AOT, open the BudgetModel table, and change its lookupBudgetModel() method with the following code: public static void lookupBudgetModel(FormStringControl _ctrl, boolean _showStopped = false) { Args args; Object formRun; args = new Args(); args.name(formStr(BudgetModelLookup)); args.caller(_ctrl); formRun = classfactory.formRunClass(args); formRun.init(); _ctrl.performFormLookup(formRun); } 8. To see the results, open Budgeting | Common | Budget register entries. Start creating a new entry by clicking on the Budget register entry button in the action pane, and expand the Budget model lookup: Источник: http://axmas.blogspot.com/2012/11/bu...ee-lookup.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
