Старый 04.01.2019, 17:13   #1
axaptacorner: How to read excel and update record in AX2012 through X++ code
Источник: http://axaptacorner.blogspot.com/201...record-in.html
static void POCUpdatePurchaseDetails_JS(Args _args)
SysExcelApplication application;
SysExcelWorkbooks workbooks;
SysExcelWorkbook workbook;
SysExcelWorksheets worksheets;
SysExcelWorksheet worksheet;
SysExcelCells cells;
COMVariantType type;
Dialog dialog = new Dialog("Excel upload utility");
dialogField dialogFilename;
int row;
int totalUpdatedRecord = 0;
FileName filename;
InventTable inventTable;
ItemId itemId;
ItemGroup itemGroup;
InventTableModule inventTableModule;
application = SysExcelApplication::construct();
workbooks = application.workbooks();
dialogFilename = dialog.addField(extendedTypeStr(FilenameOpen),"@SYS53125");
dialog.filenameLookupTitle("Update data from excel file");
dialog.filenameLookupFilter(["@SYS28576",'*XLSX', "@SYS28576",'*XLS']);
if (!dialog.run())
return;
filename = dialogFilename.value();
try
workbooks.open(filename);
catch (Exception::Error)
throw error("File cannot be opened.");
workbook = workbooks.item(1);
worksheets = workbook.worksheets();
worksheet = worksheets.itemFromNum(1);
cells = worksheet.cells();
row=1;
do
row++;
itemId = cells.item(row, 1).value().bStr();
ttsbegin;
inventTable = InventTable::find(itemId,true);
inventTableModule=InventTableModule::find(inventTable.ItemId,ModuleInventPurchSales::Purch,true);
if (inventTable)
inventTableModule.Price=str2num(cells.item(row, 2).value().bStr());
inventTableModule.PriceUnit=str2num(cells.item(row, 3).value().bStr());
inventTableModule.update();
totalUpdatedRecord++;
ttscommit;
type = cells.item(row+1, 1).value().variantType();
while (type != COMVariantType::VT_EMPTY);
application.quit();
info(strFmt('Data updated, total record=%1 record',totalUpdatedRecord));
Часовой пояс GMT +3, время: 18:35.
