Старый 04.05.2009, 20:05   #1
SysDictCoder: Dealing with containers
Источник: http://sysdictcoder.com/blog/dealing-with-containers/
The X++ container is a powerful and somewhat odd datatype. It’s like an array but supports different data types in the same instance and it can grow infinitely large. Also containers don’t have methods like real objects; you need to call special functions and pass your container to them.
Many data structures in X++ are serialized (packed) into containers before they’re sent across the network or stored in the database. The entire SysLastValue framework runs on it.
Unfortunately this kind of flexibility is often abused. It’s very easy to abuse containers and I see it happen too often. In this article I’ll go over some good practices for containers. I won’t go into basics of containers. You can find basic documentation on MSDN (methods starting with con).
Appending to containers
Most of the time you want to append something to a container. Typically I come across code like this:
<div class="wp_syntax"><div class="code">for (i=1; i
container, x++
SysDictCoder: Changing properties of AOT objects in code Blog bot DAX Blogs 0 04.05.2009 20:05
SysDictCoder: A quick fix for unbalanced TTS Blog bot DAX Blogs 0 04.05.2009 20:05
SysDictCoder: Moving the blog Blog bot DAX Blogs 1 05.07.2007 01:56
SysDictCoder: 10 tips for debugging in Dynamics Ax Blog bot DAX Blogs 0 01.07.2007 22:05
SysDictCoder: SafeMap Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 14:02.
