Старый 04.05.2009, 20:05   #1
SysDictCoder: A quick fix for unbalanced TTS
Источник: http://sysdictcoder.com/blog/a-quick...nbalanced-tts/
During development you may encounter one of these.
This usually leaves your Ax session in an unusable state that you can’t close properly. However, there’s no need to get out the big guns and kill the process with the Task Manager.
Instead, if possible, open the AOT and run this job:
static void resetTTS(Args _args){ while (appl.ttsLevel() > 0) ttsAbort;}
It simply rolls back any pending transactions until the TTS level is back at zero. Now, this doesn’t fix the cause of the problem but it makes life easier trying to iron out the bug.
x++
AX UK: Dynamics AX Quick Reference Guide Blog bot DAX Blogs 0 27.07.2007 17:30
gl00mie: AX4 SysFileDeployment Fix Blog bot DAX Blogs 0 10.07.2007 16:20
SysDictCoder: Moving the blog Blog bot DAX Blogs 1 05.07.2007 01:56
SysDictCoder: 10 tips for debugging in Dynamics Ax Blog bot DAX Blogs 0 01.07.2007 22:05
dynamicsmatters: New Fix distribution policy Horror from MS Blog bot DAX Blogs 0 16.04.2007 17:50
Часовой пояс GMT +3, время: 03:35.
