Старый 25.09.2014, 01:24   #1
How to find in AOT all objects named like...
Источник: http://alexvoy.blogspot.com/2014/09/...cts-named.html
In fact the standard Find tool in AOT works well if you really know how to fill in all these parameters before launch it. Sometimes it is easier to use another options.
Let's say we need to find all the forms that contain 'lookup' word in the end of their names. Easy? Yes, it is! You can go directly to the SysModelElement table and work with it as with any other table: Ctrl-G to switch grid filter, 11 for Form element type, then *lookup in the name, and that's it.
This is rapid way to know the objects names but it is not possible to jump to them in AOT. Here we go with the second option. Just create a new project and filter criteria Element type name and Name for the objects.
Simple, fast and will keep the search results for future recalls.
Happy searching in AOT!
bojensen: How to find All USR Layer Elements in AOT Blog bot DAX Blogs 0 15.05.2014 19:11
How to find your object in AOT projects Blog bot DAX Blogs 0 03.05.2011 06:15
To find objects in AOT with particular properties Blog bot DAX Blogs 1 26.04.2008 07:33
axStart: How to find line of code with a question mark in your AOT. Blog bot DAX Blogs 0 16.04.2008 22:05
C# and AX Development: How to delete AOT objects (AX/Axapta) Blog bot DAX Blogs 0 13.12.2007 19:50
Часовой пояс GMT +3, время: 19:59.
