Старый 16.04.2008, 22:05   #1
25,643 / 848 (80) +++++++
axStart: How to find line of code with a question mark in your AOT.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!294.entry
Sometimes you need to find special characters like a?.  It will result in all the code and not just only the code with ‘?’
If you just add a ‘\’ (backslash) before your question mark. Your results will be exactly what you need (newline = \n Tabspace = \t).
Dynamics AX FAQ: How to find an AOT object by its property? Blog bot DAX Blogs 2 07.11.2008 12:54
axStart: Starting the code profiler from code Blog bot DAX Blogs 0 17.03.2008 15:05
axStart: What to do when AIF is not working and how to code: Blog bot DAX Blogs 0 23.12.2007 17:51
Malaysia: How to Run Time Add Code to AOT Blog bot DAX Blogs 0 18.09.2007 15:00
daxmy: AOT Find function Blog bot DAX Blogs 0 17.08.2007 01:23
Часовой пояс GMT +3, время: 12:35.
