Старый 11.10.2016, 18:11   #1
organicax: Marking a menu as a favorite in AX7
Источник: https://organicax.com/2016/10/11/mar...vorite-in-ax7/
In the new AX there are quite a few new ways to get around to find the functionality you need, for example the menu search. If you like using the menu navigation for functions that are not in a workspace but you want quick access to you can use the favorite links.
Here is a quick overview.
AX7 Build 7.0.4230.16130
It’s a reminder that the new AX being HTML you can also use the favorites options in the browser you are using to access AX. All you need to do is navigate to a form in AX and use your browser’s favorite button.
Cheers
Lachlan
Filed under: User tips
organicax: Enabling an employee for MES, Shop Floor in AX7 Blog bot DAX Blogs 0 28.09.2016 22:15
organicax: WMS Mobile Device indirect menu items – compile of posts. Blog bot DAX Blogs 0 03.09.2016 01:24
organicax: WMS Mobile device menu – Start production order Blog bot DAX Blogs 0 01.09.2016 01:18
organicax: WMS menu – movement by template Blog bot DAX Blogs 0 12.05.2016 20:14
atinkerersnotebook: Creating One Master Menu to Get Just What You Need Blog bot DAX Blogs 0 24.01.2015 16:16
Часовой пояс GMT +3, время: 03:24.
