Старый 12.05.2016, 20:14   #1
organicax: WMS menu – movement by template
Источник: https://organicax.com/2016/05/11/wms...t-by-template/
In a previous post we have a look at the movement menu item. There is another option which is movement by template. The added advantage of using the movement by template is that you can use the work template and the locations directives to setup a process around the movement.
Here is a quick overview.
AX2012 R3 CU9
As you will see in this example the system is updated and the assumption is the physical stock is moved at the same time. There is an option to delay the move with the create movement parameter on the menu.
Cheers
Lachlan
Filed under: Warehouse management
organicax: Movement by template – create movement Blog bot DAX Blogs 0 12.05.2016 20:14
organicax: WMS Mobile device menu – Display batch disposition codes Blog bot DAX Blogs 0 10.05.2016 17:11
organicax: Assigning a WMS work template to a disposition code Blog bot DAX Blogs 0 10.05.2016 10:11
organicax: WMS Wave template – wave attributes Blog bot DAX Blogs 0 19.03.2016 00:14
organicax: WMS Wave template – line threshold Blog bot DAX Blogs 0 15.03.2016 23:11
Часовой пояс GMT +3, время: 07:55.
