Старый 16.04.2007, 23:51   #1
Harish Mohanbabu: Table set / get properties
Источник: http://harish-m.livejournal.com/24306.html
Ever since I changed job, it has been a busy period. Any way one of the questions I have noticed often is about setting and getting table properties by X++. This can be accomplised by using 'TreeNode' class. Here are some examples -
Get table properties
Let us say we want to get 'Security key' table property for all tables. Here is a sample code -
static void getTableProperty(Args _args)
    Author      :       Harish Mohanbabu
    Date        :       April 16, 2007
    Purpose     :       To obtain table properties
    #AOT
    str             Property;
    TreeNode        TreeNode;
    identifiername  identifiername;
    str             Name;
    TreeNode    = TreeNode::findNode(#TablesPath);
    TreeNode    = TreeNode.AOTfirstChild();
    while (TreeNode)
            Name = TreeNode.AOTname();
            Property       = TreeNode.AOTgetProperties();
            identifiername = findproperty(Property, 'SecurityKey');
            info (strfmt("%1, %2", Name, identifiername));
            treenode = TreeNode.AOTnextSibling();
Set table properties
Let us say we want to set 'modified date' table property to yes for all 'CustTable'.
static void setTableProperty(Args _args)
    str                Property;
    TreeNode    TreeNode;
    str               Name;
    Name = "CustTable";
    TreeNode  = TreeNode::findNode("Data Dictionary\\Tables\\" + Table);
    if (TreeNode)
           ttsbegin;
           Property       = SetProperty(Property, "ModifiedDate", "Yes");
           TreeNode.AOTsetProperties(Property);
           TreeNode.AOTcompile();
           TreeNode.AOTsave();
Note - if you are planning to use the above code, please make sure you first do this in a test environment.
Harish Mohanbabu: Hardware sizing guides for Ax 2009? Blog bot DAX Blogs 0 12.10.2008 14:07
Harish Mohanbabu: Survey on .NET Business Connector for Partners Blog bot DAX Blogs 0 24.06.2008 18:05
Harish Mohanbabu: Inside Microsoft Dynamics Ax 4.0 - Free eBook! Blog bot DAX Blogs 0 16.04.2008 15:05
axStart: Mass update on table properties Blog bot DAX Blogs 0 15.12.2007 01:11
Harish Mohanbabu: Axapta 3.0 compilation errors Blog bot DAX Blogs 0 14.06.2007 22:14
Часовой пояс GMT +3, время: 03:02.
