Старый 14.06.2007, 22:14   #1
Harish Mohanbabu: Axapta 3.0 compilation errors
Источник: http://harish-m.livejournal.com/24899.html
Some times when merging different layers using .AOD (Application object files) files, Ax compiler might throw compilation errors related to parameters in methods. To resolve instances like this, there was an article published in the old TechNet.
In that article the author recommended running a job which will delete the old table and class headers in the AOD. Here is this job -
static void deleteHeaders(Args _args)
    UtilElements utilElements;
    while select utilElements where
    utilElements.recordType ==UtilElementType::ClassInternalHeader
        utilElements.delete();
        utilElements.recordType ==UtilElementType::TableInternalHeader
Warning - Please run this job at your risk. I do not provide any guarantee or any warranty.
Harish Mohanbabu: Hardware sizing guides for Ax 2009? Blog bot DAX Blogs 0 12.10.2008 14:07
Harish Mohanbabu: Microsoft Dynamics Ax / Database support details Blog bot DAX Blogs 0 19.04.2007 00:33
Harish Mohanbabu: Table set / get properties Blog bot DAX Blogs 2 17.04.2007 15:28
Часовой пояс GMT +3, время: 11:45.
