Старый 01.04.2011, 13:11   #1
msdax: Date Range in AOT Query from SSRS
Источник: http://msdax.blogspot.com/2011/03/da...from-ssrs.html
[LEFT]
Query:
How can I add date ranges in an AOT query linked to SSRS.
Answer:
Kindly use the following sample code to create a data method and then use it as a source for report data set.
[DataMethod(), AxSessionPermission(SecurityAction.Assert)]
public static DataTable GetData(DateTime fromDate, DateTime toDate)
        DataTable table = new DataTable();
        IDictionary myRanges = new Dictionary();
        myRanges.Add("AOTTable.Date", fromDate.ToString("dd/MM/yyyy") + ".." + toDate.ToString("dd/MM/yyyy"));
        table = AxQuery.ExecuteQuery("select * from AOTQuery", myRanges);
        return table;
Последний раз редактировалось Poleax; 01.04.2011 в 13:44.
msdax: How to Specify Range Values on a Query in a AX SSRS Report - AX Support - Site Home - MSDN Blogs Blog bot DAX Blogs 0 31.03.2011 11:11
dynamics-ax: Expert SSRS with AX Tip from Michael Stashwick Blog bot DAX Blogs 0 14.01.2011 05:18
palleagermark: Sample union query from AX 2009 Blog bot DAX Blogs 0 11.07.2008 20:05
axaptapedia: Packing date range values in queries Blog bot DAX Blogs 1 09.11.2007 13:10
Fred Shen: Date data type in Query Range Value Expression Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 11:55.
