Старый 11.07.2008, 20:05   #1
palleagermark: Sample union query from AX 2009
Источник: http://palleagermark.blogspot.com/20...m-ax-2009.html
Queries build with the Query classes now supports unions, meaning that you can combine the result from several tables into one result set. The results you want to combine from the different tables must be structured the same way for all tables.
You could for example create a query combining CustTable and VendTable. This would be particularly useful if you need to present for example a lookup form showing both customers and vendors in the same grid. In earlier version you’d have to push customer and vendor data to a temporary table before being able to present the combined data in one grid.
Here is an example on how to build and use a union query from X++:
static void union(Args _args)
    Query                query;
    QueryBuildDataSource qbdsCustTable;
    QueryBuildDataSource qbdsVendTable;
    QueryRun             queryRun;
    CustTable            custVendTable;
    Map                  mapTableBranches = new Map(types::Integer, typeId2Type(typeId(TableId)));
    SysDictTable         dictTable;
    // The map is used to match the UnionBranchID with a table id
    mapTableBranches.insert(1, tableNum(CustTable));
    mapTableBranches.insert(2, tableNum(VendTable));
    query = new Query();
    query.queryType(QueryType::Union);
    qbdsCustTable = query.addDataSource(tableNum(CustTable));
    qbdsCustTable.unionType(UnionType::UnionAll); // Include duplicate records
    qbdsCustTable.fields().dynamic(false);
    qbdsCustTable.fields().clearFieldList();
    qbdsCustTable.fields().addField(fieldNum(CustTable, AccountNum));
    qbdsCustTable.fields().addField(fieldNum(CustTable, Name));
    qbdsVendTable = query.addDataSource(tableNum(Vendtable));
    qbdsVendTable.unionType(UnionType::UnionAll); // Include duplicate records
    qbdsVendTable.fields().dynamic(false);
    qbdsVendTable.fields().clearFieldList();
    qbdsVendTable.fields().addField(fieldNum(VendTable, AccountNum));
    qbdsVendTable.fields().addField(fieldNum(VendTable, Name));
    queryRun = new QueryRun(query);
    queryRun.prompt();
    while (queryRun.next())
        custVendTable = queryRun.getNo(1);
        dictTable = SysDictTable::newTableId(mapTableBranches.lookup(custVendTable.unionAllBranchId));
        info (strFmt("%1 %2 (%3)", custVendTable.AccountNum,
                                   custVendTable.Name,
                                   dictTable.name()));
msdynamicsax: Upgrading a database from Ax 4.0 SP1 to Ax 2009 Blog bot DAX Blogs 1 13.08.2008 14:02
Khue Trinh: AX 2009 Quality Management - Quality Control Blog bot DAX Blogs 1 04.07.2008 16:01
Часовой пояс GMT +3, время: 19:24.
