Старый 17.07.2012, 18:11   #1
emeadaxsupport: POS printer is not recognized by POS (AX2009 & AX2012)
Источник: http://blogs.msdn.com/b/axsupport/ar...mp-ax2012.aspx
Description:
When launching the POS.exe it is loading the devices found in the POS hardware profile and establish the connection through Common Control Object (CCO). The POS printer is not loaded and the pos returns with the message that the printer can´t be found.
Cause:
Even that the user is administrator on the local machine, the access through the Common Control Object (CCO) is not possible. We have seen this issue on windows 7 and with certain printers like
HP A799 printer
Citizen CT-S2000 printer
Solution:
The solution is to set the Privilege level: "Run this program as administrator"
Author: Kim Truelsen
Date: 17/7-2012
emeadaxsupport: AX2012 POS: Adding a new line is slow Blog bot DAX Blogs 0 21.04.2012 13:12
emeadaxsupport: AX2012 and AX2009 or AX4 side by side - AOS performance counters overwritten Blog bot DAX Blogs 0 13.03.2012 18:11
emeadaxsupport: Retail: How to access multiple POS from one machine Blog bot DAX Blogs 0 26.08.2011 21:13
emeadaxsupport: Buttons in the POS layout are not all localized. Blog bot DAX Blogs 0 25.08.2011 19:11
emeadaxsupport: Printer defaults to letter instead of A4 - how AX finds the default printer Blog bot DAX Blogs 0 27.04.2011 22:11
Часовой пояс GMT +3, время: 03:22.
