Старый 25.08.2011, 19:11   #1
25,643 / 848 (80) +++++++
emeadaxsupport: Buttons in the POS layout are not all localized.
Источник: http://blogs.msdn.com/b/emeadaxsuppo...localized.aspx
Topic:
The text is displayed in English only
Here is a preview from the POS till layout
Solution:
Modification needed to change the label of the ”fixed” image
button.
Step by step example
  1. Go to the AOT/resources and find RBO_Image_110_png
  2. Open the resource file and press export
3. Edit the files with example a picture editor
4. Go to the Retail Headquarters/Setup/RetailPOS/Button Grid
5. Choose Payments and press the designer button
6. Mark the Currency and click on the Button properties
7. Right click and go to main table on the PictureID (110)
8. Press select and mark your changed picture file and ok
9. The result is like this
10. Go now to the Retail Scheduler and replicate the N-1090 Terminals job
11. Log into POS
The result is that the button now changed.
Author: Kim
Editor: Kim
Date: 25. August 2011
emeadaxsupport: Kerberos authentication does not work when Enterprise Portal uses a non-standard port Blog bot DAX Blogs 0 14.02.2011 21:11
emeadaxsupport: The Dynamics AX 2009 AOS does not start with "The license information can not be decoded" error Blog bot DAX Blogs 0 22.09.2010 23:05
emeadaxsupport: Unable to validate workflow URL in AX 2009 - Get the following error: The request failed with HTTP status 405: Method Not Allowed Blog bot DAX Blogs 0 07.07.2010 23:05
emeadaxsupport: Warning when loading license file - License value for ID 2024 has not been created (or License value for ID 2025 has not been created) Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 15:25.
