#8 |
X++: // AOSRunMode::client - this method is always called on the client, which eliminates the need for a CAS assert. public static client DocuValue writeDocuValue(DocuRef docuRef, Filename filename = '', BinData binData = null) { DocuValue docuValue; DocuType docuType; ; ttsbegin; docuType = docuRef.docuType(); docuValue = docuRef.docuValue(true); [docuValue.FileName, docuValue.FileType, docuValue.Path] = Docu::splitFilename(filename); if (docuType.FilePlace != DocuFilePlace::NoCopy) docuValue.Path = ''; //path is already stored in ArchivePath in docuType or docuParameters if (docuType.FilePlace == DocuFilePlace::Database) { // Insert to database if (WinAPI::fileLocked(filename)) { info("@SYS72783",'',SysInfoAction_Formrun::newFormnameControlnameDesc(formstr(DocuOpenFile), identifierstr(Grid), "@SYS4167")); } else { if (! binData) { binData = new BinData(); if (binData.loadFile(filename)) //only works if file not locked { docuValue.File = binData.getData(); } else throw error(strfmt("@SYS54217",filename)); } else docuValue.File = binData.getData(); } } docuValue.update(); ttscommit; return docuValue; } Последний раз редактировалось petr; 23.07.2007 в 13:58. Причина: Более полный ответ |
