Старый 27.08.2007, 23:00   #1
dax-lessons: Setting Configurations - by simple Job run
Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!121.entry
Axapta - Configurations through X++ Code
Guys...fed up of setting up the configurations after installing AX..by checking and unchecking the modules..
Here is the small utility that saves your time if you want to use all the modules...
Usually we go to the Administration->SetUp->System->Confiuration and we configure the modules(check/uncheck)
Just run the job, it will configure the modules (remember the code which is commented is to just give u an example
how to configure a single module.This job will enable all the modules)and synchronise the tables as well.
If you want to configure specifically some modules , you can check the commented logic in the code below and customise accordingly.
<blockquote dir=ltr> <blockquote dir=ltr> static void changeSystemConfiguration(Args _args)
    ConfigurationKeySet     set;
    ConfigurationKeyId      id;
    SysDictConfigurationKey sysDictConfigurationKey;
    int     i;
    Args    args;
    FormRun formRun;
    set = new ConfigurationKeySet();
<blockquote dir=ltr> <div><font color="#993366">    for(i = 1; i
dax-lessons: Alert user using Net send - x++ Blog bot DAX Blogs 0 17.09.2008 13:05
dax-lessons: Create Outlook Appointment or Meeting Request using X++ Blog bot DAX Blogs 0 30.04.2008 23:07
dax-lessons: Weather forecasting using X++ Blog bot DAX Blogs 2 25.04.2008 12:00
dax-lessons: Active directory in Axapta Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 22:49.
