Старый 11.03.2009, 15:01   #10
Venice is offline
Venice
спасибо, а как определить какой из методов подходит? и подскажите как это делается? "Create new string value...." где это делается и как ? заранее спасибо
Method 1
Note Use this method if the Library string value does not exist.
Create a new string value under the Category Regkey\Performance subkey, and then specify the string value as follows:
  • Name: Library
  • Value data: netfxperf.dll
Note The Category Regkey placeholder represents the actual path of the category registry key.
Back to the top
Method 2
Note Use this method if the value data of the Library string value is not "netfxperf.dll."
Change the value data of the Library string value to "netfxperf.dll."
Back to the top
Method 3
Note Use this method if the First Counter value does not exist.
If the counter category is specified by Microsoft Dynamics CRM, run a repair process of Microsoft Dynamics CRM. The repair process can regenerate correct values of the performance counter registry keys.
If the counter category is specified by Windows Workflow Foundation, run the following command to re-create the First Counter value and the Last Counter value:
lodctr "c:\windows\Microsoft.NET\Framework\v3.0\Windows Workflow Foundation\PerfCounters.ini"
crm, outlook
Microsoft Dynamics CRM Team Blog: FAQ: Using both BCM and CRM Add-ins with Outlook Blog bot Dynamics CRM: Blogs 0 04.04.2009 03:19
Microsoft Dynamics CRM Team Blog: Drowning in Outlook Reminders? This might help. Blog bot Dynamics CRM: Blogs 0 18.02.2009 21:05
Установка offline- Outlook клиента Lazarus Dynamics CRM: Администрирование 1 29.10.2008 07:58
Мир CRM: Зависание папки “Входящие” на стадии загрузки Outlook - Хотфикс готов Blog bot Dynamics CRM: Blogs 2 18.08.2008 19:50
Microsoft Dynamics CRM Team Blog: CRM4 Outlook Client – Issues and Fixes Blog bot Dynamics CRM: Blogs 0 07.08.2008 01:05
Часовой пояс GMT +3, время: 10:27.
