Старый 29.10.2009, 18:05   #1
emeadaxsupport: How does the AX Hotfix / Service Pack installer detect existing AOS instances
Источник: http://blogs.msdn.com/emeadaxsupport...instances.aspx
Have you ever wondered how the AX Hotfix / Service Pack installer detects existing AOS instances?
These information can be found in the Installer Registry under the following Registry Key:
HKEY_CLASSES_ROOT\Installer\Products
Every AOS Instance has it's own class Id.
This class id looks like this FA15D12F8BB2D1C4282780DBCF31Axxx (where xxx is a uniqe number).
For example:
If I have 2 AOS instances on my machine then I may find the following registry keys:
HKEY_CLASSES_ROOT\Installer\Products\FA15D12F8BB2D1C4282780DBCF31A110
HKEY_CLASSES_ROOT\Installer\Products\FA15D12F8BB2D1C4282780DBCF31A120
Additional information
If those keys have a subkey named Patches then they are marked as updated.
The entries in this subkey contain information about the applied patches.
daxcoder: Hotfix rollup 3 is available for Microsoft Dynamics AX 2009 Service Pack 1 Blog bot DAX Blogs 0 02.10.2009 05:14
Hotfix rollup 967145 is available for Microsoft Dynamics AX 2009 Service Pack 1 Dima_Dima DAX: Программирование 7 08.05.2009 11:29
Feature Pack 1 for Microsoft Dynamics AX 3.0 Service Pack 6 EE Poleax Microsoft и системы Microsoft Dynamics 3 24.02.2009 18:14
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Service Pack 1 Released Blog bot DAX Blogs 5 21.11.2008 17:00
Часовой пояс GMT +3, время: 06:59.
