Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 18.06.2011, 15:29   #10
Logger is offline
Logger
3,997 / 3298 (117) ++++++++++
Записей в блоге: 2
Сообщение от Alex_KD Посмотреть сообщение
Try to stick with this one.
You should be able to get all AOT elements that were modified.
Please find the sample xpp code, which returns all elements that were modified in the last 5 minute (300 second), below:
 UtilIdElements          utilIdElements;
         utcdatetime        datetime;
         date   modifyDate;
          begin = WinApi::getTickCount();
          modifyDate = systemdateget();
          datetime = DateTimeUtil::newDateTime(modifyDate,  ((timenow() - 300) > 0)?(timenow() - 300):(0));
          while select name, id, recordType from utilIdElements
          where  (utilIdElements.createdDateTime > datetime) ||
               (utilIdElements.modifiedDateTime > datetime)
                switch(utilIdElements.recordType)
It's correct only for build 1500.4570
see
kb2472202 The ChangedDate field and the ChangedTime field on a class are not updated when you change the class in Microsoft Dynamics AX 2009 SP1
За это сообщение автора поблагодарили: Dark Smile (1).
axdaily: SQL temporary tables in AX 2012 Blog bot DAX Blogs 25 06.05.2011 10:18
sumitsaxfactor: AOSAuthorization property on tables Blog bot DAX Blogs 0 06.05.2011 02:19
Prabhats: DAX 2009: Temporary Tables in Enterprise Portal Blog bot DAX Blogs 0 27.04.2011 11:11
axhelper: How to Use Temporary tables in reports Blog bot DAX Blogs 0 29.09.2010 18:05
Microsoft Dynamics AX AIF: Sending Outbound Documents Automatically Blog bot DAX Blogs 0 31.03.2008 11:05
Часовой пояс GMT +3, время: 20:43.
