Старый 14.11.2011, 14:50   #5
Omalinka is offline
Omalinka
Скопировала библиотеку sample_/Scripts/SDK.REST.js к себе в solution и пытаюсь проапдейтить custom entity "steer_participant" аналогично тому, как приведено в примере http://technet.microsoft.com/en-us/l...taOperationsJS.
Но ничего не просиходит, что я делаю не так..?
function updateParticipant(ParticipantId) {
	 var participant = {};
	 alert("Changing the participant status");
	 participant.steer_attended = true;
	 SDK.REST.updateRecord(
		 ParticipantId,
		 participant,
	     "steer_participant",
	     function () {
	      alert("The account record changes were saved");
	      deleteParticipant(ParticipantId);
	     errorHandler
function deleteParticipant(ParticipantId) {
 if (confirm("Do you want to delete this account record?")) {
  writeMessage("You chose to delete the account record.");
  SDK.REST.deleteRecord(
       ParticipantId,
       function () {
        writeMessage("The account was deleted.");
        enableResetButton();
       errorHandler
 else {
  var li = document.createElement("li");
  var span = document.createElement("span");
  span.innerText = "You chose not to delete the record. You can view the record ";
  var link = document.createElement("a");
  link.href = SDK.REST._getServerUrl() + "/main.aspx?etc=1&id=%7b" + AccountId + "%7d&pagetype=entityrecord";
  link.target = "_blank";
  link.innerText = "here";
  li.appendChild(span);
  li.appendChild(link);
  output.appendChild(li);
Gareth Tucker: Adding a new Button Group to the CRM Ribbon Blog bot Dynamics CRM: Blogs 0 24.08.2011 16:11
Gareth Tucker: Editing Ribbon Buttons in CRM 2011 Blog bot Dynamics CRM: Blogs 0 24.08.2011 09:11
Dynamics CRM Tools: New tool (alpha) : Ribbon Editor Blog bot Dynamics CRM: Blogs 0 14.07.2011 17:11
Dynamics CRM Tools: New tool: Ribbon Browser Blog bot Dynamics CRM: Blogs 0 15.06.2011 18:11
Microsoft Dynamics CRM Team Blog: Create Dynamic Ribbon Controls Blog bot Dynamics CRM: Blogs 0 30.03.2011 21:11
Часовой пояс GMT +3, время: 13:23.
