Старый 06.01.2012, 21:13   #1
axaptacorner: Label are not shown
Источник: http://axaptacorner.blogspot.com/201...not-shown.html
This is commen error while importing XPO, it reflects the xpo but label are seen in not deployed form
most possible reason is not tick application files and labels radio button at the time of exporting or importing
Solution:
1.Tick application files and label at the time of importing
2.Put the relevent .ald file for en-in and path is drive->program file->dynamics Ax->50->Application->appl->dynamics ax
I hope it will work fine!!!!!!!
axaptacorner: License is not exist for language en-in Blog bot DAX Blogs 0 03.10.2011 18:11
axaptacorner: Not enough rights to use table 'Signature log' (SIGSignatureLog) Blog bot DAX Blogs 0 24.07.2011 14:14
emeadaxsupport: How label flushing works under the hood Blog bot DAX Blogs 0 17.08.2010 16:05
palleagermark: Sorting of versions shown in the Compare tool, when using MorphX version control, is not correct Blog bot DAX Blogs 0 05.02.2010 15:05
Часовой пояс GMT +3, время: 09:13.
