#1 |
emeadaxsupport: Content news: June
Источник: http://blogs.msdn.com/b/axsupport/ar...news-june.aspx
============== Hi everyone, The Dynamics AX content publishing team has posted new and updated content for Microsoft Dynamics AX to TechNet and MSDN. To read about our documentation resources and where to find updated content see: the document Help and Resources Datasheet for Microsoft Dynamics AX 2012; and the blog post Official Dynamics AX 2012 Content. The following table contains links to each group of topics that we have added or updated since May. Audience Approximate number of topics published White papers and Guides 4 System Administrator topics 1 Developer topics 12 Topics published on both MSDN and TechNet (Analytics and Services) 3 White Papers and Guides The following white papers and guides have been published or updated since May. AX 2009 BOM calculation using Costing Sheet Microsoft Dynamics AX 2012 Implementation Planning Guide Microsoft Dynamics AX Data Provider for Management Reporter 2012 Country-specific update guides RU8 Country-specific updates for the Russian Federation System Administrator topics The following topics have been published or updated on TechNet. Models, Layers, and the Model Store Troubleshooting working with model files Developer topics The following topics have been published or updated on MSDN. Debugging in Microsoft Dynamics AX 2012 Microsoft Dynamics AX 2012 for Developers / Security for Microsoft Dynamics AX Automatic Inference of Permissions in AOT Security Code Example: SecurityUtil Class for Accessing Role and Object Permissions Microsoft Dynamics AX 2012 for Developers / X++ Language Programming Guide Declaration of Classes How to: Use the #globaldefine Directive to Avoid Overwriting Using Optional Parameters X++, C# Comparison: Switch Microsoft Dynamics AX 2012 for Developers / Database for Microsoft Dynamics AX / Queries in the AOT for Data Access Cross-Company and the company Getter Method How to: Create Queries by using the AOT Using Expressions in Query Ranges Microsoft Dynamics AX 2012 for Developers / Integration with Microsoft Dynamics AX Propagate Infolog Messages to the Windows Event Log Scenarios for Constructing Proxy Objects Topics on both TechNet and MSDN The following topics have been published or updated on both TechNet and MSDN. Analytics Configure Analysis Services by running Setup Services and Application Integration Framework (AIF) AIF Document Services Example Messages for AIF Document Service Operations Источник: http://blogs.msdn.com/b/axsupport/ar...news-june.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
