axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework new version released
Источник: http://blogs.msdn.com/b/axsa/archive...w-release.aspx
We have released the new version for Microsoft Dynamics AX 2012 Data Import/Export Framework. Besides the new features we added we have also moved DIXF to Foundation as part of Microsoft Dynamics AX 2012 R2 CU7.
What’s New :
- Part of foundation layer in CU7.
- 150 Entitiesout of the box ( 80+ new entities added)
- Master Data
- Reference Data
- Journals
- System Configuration data
- Application configuration data – Parameters, Reference data, etc.
- New Retail specific entities
- New file types added for import as well as export
- XML file – attribute and element based.
- Excel file
- Compare and copy entity data across companies
- Copy entity data across companies
- Support for exporting data in multiple formats – delimited, fixed width, XML and excel for bulk data.
- Role based security and privacy extension for Entities and Processing Group
- Securing Processing group by company.
- Enhancements to custom entity creation
Download it now!
- Microsoft Dynamics AX 2012 R2 Cumulative Update 7 (KB2885603 )
Key features
- 150+ Entities out of the box
- Support for creating custom entities using Custom entity creation wizard.
- Import Entity data from multiple sources
- Flat File – Delimited and Fixed Width
- XML – XML file
- Excel – Excel file
- ODBC – external data bases , Excel files , etc.
- Export Entity data from AX 2012 to
- Other AX 2012 environments
- Flat File , XML File and Excel file
- Compare and Copy Entity data across Legal entities
- Entity types – Entity, composite entity and flat table.
- Mapper control
- Parallel execution support from staging to target using Task Bundling
- Folder as input for running periodic import - with functionality to move files to different folders (In Process, Error and Completed)
- Error handling - skipping error rows , etc.
- Set based support for staging to target
- Default value Support
- Number sequence Support
- External Key mapping Support
- · Source to Target in single step
- · Multiple AOS support
.. and lot more.
