Старый 28.09.2016, 16:11   #1
emeadaxsupport: Check AOS event logs and SQL Server error logs for key messages using DynamicsPerf
Источник: https://blogs.msdn.microsoft.com/axs...-dynamicsperf/
As part of general monitoring of Dynamics AX overall system health and/or troubleshooting, you’ll want to check the Windows event logs in your AOS server(s) and SQL Server error logs. If you have DynamicsPerf (Performance Analyzer for Microsoft Dynamics) installed, you can quickly check for key messages and if necessary, export and move them all... Read more
eventlog
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1A [Introduction and SQL Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
dynamicsusers: Blocks & Deadlocks in NAV with SQL Server Blog bot Dynamics CRM: Blogs 0 18.04.2008 10:23
Часовой пояс GMT +3, время: 23:12.
