Старый 28.10.2006, 16:40   #1
Solutions Monkey: Accessing SharePoint Document Library through UNC Path.
Источник: http://blogs.msdn.com/solutions/arch...19/671873.aspx
If you have an Enterprise Portal site with the URL http://AX40VPC/Sites/EnterprisePortal and you need to access the document libraries in this site through windows explorer through the UNC path \ax40vpc\sites\enterpriseportal from a windows 2003 server , then you need to start the WebClient service on the OS. This service is by default disabled in Windows 2003. So go to Administrative Tool -> Services to start this service.
Also if you have enabled Basic Auth on this site , then you need to follow the instructions given in http://support.microsoft.com/?kbid=841215
Solutions Monkey: Integrating EP Web Parts to non-EP SharePoint sites Blog bot DAX Blogs 0 04.04.2009 03:19
Solutions Monkey: Setting up EP in NLB Cluster Blog bot DAX Blogs 0 18.10.2008 02:08
Solutions Monkey: SharePoint Tips & Tricks Blog bot DAX Blogs 0 20.01.2008 08:14
Solutions Monkey: Microsoft Dynamics AX Enterprise Portal Customer Self Service Scenarios Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 18:32.
