Старый 26.01.2007, 05:51   #1
Kashperuk Ivan: A little modification / add-on to Sidax:I use on...
Источник: http://kashperuk.blogspot.com/2006/1...o-sidax-i.html
I use one of the features of Sidax most of all - it's the recent projects tab. (we have a lot of projects and I have to work with a lot of them at the same time). So performance of this tab is most critical to me.
And what was wrong is that from time to time I would stumble onto project names that didn't exist anymore, but still were up high in the list of recent projects.
So what this modification does is just verify that the project exists before showing it in the list of recent projects.
(this verification is performed only when the recent projects tab is opened, so it won't cause any performance issues)
To add this modification into your sidax installation, you have to do the following:
1. Add a method to Forms\Sidax:
<div style="margin:0px; padding:3px; border:2px inset; overflow:auto">void updateMruProjects()
int i;
TreeNode privateProjectTreeNode;
TreeNode sharedProjectTreeNode;
TreeNodeName projectName;
boolean existsProject(TreeNodeName _projectName)
TreeNode project;
project = privateProjectTreeNode.AOTfindChild(_projectName);
if (project)
return true;
project = sharedProjectTreeNode.AOTfindChild(_projectName);
if (project)
return true;
return false;
privateProjectTreeNode = SysTreeNode::getPrivateProject();
sharedProjectTreeNode = SysTreeNode::getSharedProject();
for(i = 1; i
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Kashperuk Ivan: 3 great Tabax Plugins Blog bot DAX Blogs 2 15.05.2007 11:55
Kashperuk Ivan: Buy MorphX IT in Russian Blog bot DAX Blogs 6 13.04.2007 17:48
Kashperuk Ivan: Adding Menu ReferencesMany developers often find... Blog bot DAX Blogs 0 26.01.2007 05:51
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 02:51.
