Старый 20.02.2007, 21:50   #1
mfp: Channel 9 screencast - Application Fundamentals
Источник: http://blogs.msdn.com/mfp/archive/20...damentals.aspx
The next installment of AX screencasts is now available on Channel9. It is a 38 minute video on Application Fundamentals in Dynamics AX 4.0.
Here is the link:
http://channel9.msdn.com/ShowPost.aspx?PostID=284365
I've attached the PowerPoint slide deck to this post. The deck contains a transcript of the talk in the slide notes. If you prefer reading to my voice, I won't blame you, and this is where you should go.
mfp: Channel 9 Screencast - MorphX Best Practices Blog bot DAX Blogs 2 21.03.2007 21:00
mfp: Dynamics Screencasts on Channel 9 Blog bot DAX Blogs 0 08.03.2007 00:44
mfp: Channel9 - AX screencast on Smart customizations Blog bot DAX Blogs 2 26.01.2007 05:45
mfp: Channel9 - AX screencast on Unit Testing Blog bot DAX Blogs 2 28.10.2006 23:31
mfp: Channel 9 on Model Driven Development Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 14:24.
