Старый 03.04.2007, 23:11   #1
25,643 / 848 (80) +++++++
casperkamal: A small addition to creation of Table throug x++ code in Dynamics Ax
Источник: http://casperkamal.spaces.live.com/B...CD63!261.entry
   A small addition to my entry on Adding a Table field through X++ code in Dynamics Ax
      I was actually using map's and structures to set the properties for the field type. There is also an alternative way of setting it throug the Global::setproperty method....
  Global::setProperty(str properties, str propertyname, str value)
 I have rewritten the job based on that.......
static void JobCreateTableFields(Args _args)
#AOT
    #TreeNodeSysNodeType
    //find the Table
TreeNode                   tablenode = TreeNode::findNode(#TablesPath).AOTfindChild('LedgerTable');
    TreeNode                   fieldNode, tn;
    Struct                         properties;
    Struct                         propertyInfo;
    Array                          propertyArray;
    str                               propertyValue;
AOTTableFieldList    lst;
    str                               name;
    Counter                     propertyCount;
    int                               i;
    Map                            map = new Map(Types::String, Types::String);
    //Find the tables field node
lst = tablenode.AOTfindChild('fields');
    //add the field
    lst.addString('Test');
    //now find the node in the tree
    fieldNode  =  lst.AOTfindChild('Test');
    //can be used when we requried to set a fewer properties
    fieldNode.AOTsetProperties(setProperty(fieldNode.AOTgetProperties(), 'Label', 'TestField'));
    //save the treenode
    tablenode.AOTsave();
//Let us open the table
    //and see if the code works :)
    tablenode.AOTnewWindow();
casperkamal: Using record templates in code for Dynamics Ax 4.0. Blog bot DAX Blogs 0 10.05.2008 19:14
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
casperkamal: Adding a Table field through X++ code in Dynamics Ax Blog bot DAX Blogs 1 02.04.2007 17:05
Часовой пояс GMT +3, время: 20:25.
