Старый 04.05.2007, 12:40   #1
DynamicsTech: Service Pack 6 for Dynamics Ax 3.0
Источник: http://dynamicstech.blogspot.com/200...ics-ax-30.html
Hi,
Microsoft has released the service pack 6 for Dynamics Ax 3.0. Click the link below for the downloads
Service Pack 6 for Dynamics Ax 3.0[Requires customer source Logon]
What Makes Microsoft Dynamics AX 3.0 SP6 Important?
Quality and Performance: The service pack will introduce corrections made to solve many
previously reported issues.
The fix lists contain detailed descriptions of improvements
System Requirements:
Microsoft Dynamics AX 3.0 Service Pack 3, 4 or 5 installed. Because the kernel portion of the installation is Microsoft Dynamics Ax 3.0 Kernel Rollup 3, with the base platform of SP3 or later, this affects the installation of SP6.
Installation Notes:
Before you install Microsoft Dynamics AX 3.0 Service Pack 6 it is necessary to read the enclosed readme file in the download package. If you do not follow the correct installation procedure described in the readme file the product may not work properly.
AX UK: Microsoft Dynamics AX 2009 Service Pack 1 Blog bot DAX Blogs 0 27.11.2008 01:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Service Pack 1 Released Blog bot DAX Blogs 5 21.11.2008 17:00
Kashperuk Ivan: Demonstration Toolkit for Microsoft Dynamics AX 4.0 Service Pack 2 is available for download Blog bot DAX Blogs 0 10.03.2008 18:06
Arijit Basu: Service Pack 2 for Microsoft Dynamics™ AX 4.0 Blog bot DAX Blogs 30 29.08.2007 21:30
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 11:38.
