Старый 03.07.2007, 17:08   #1
Kozerog is offline
Kozerog
Не пускает AOS
Переодически в течении дня возникает ситуация, когда AOS перестает пускать пользователей.
При этом в логе нахожу особщения:
Object Server EGO_WORK: Fatal SQL condition during login. Error message: "[Microsoft][ODBC Driver Manager] Driver's SQLAllocHandle on SQL_HANDLE_DBC failed"
Object Server EGO_WORK: SQL diagnostics: [Microsoft][ODBC Driver Manager] Driver's SQLAllocHandle on SQL_HANDLE_DBC failed.
Object Server EGO_WORK: The database reported (session 25 (5609)): [Microsoft][ODBC Driver Manager] Connection not open. The SQL statement was: "INSERT INTO SYSTRACETABLESQL (TRACECONTAINER,STATEMENT,CALLSTACK,TEXT,TEXTDETAILS,TRACETIME,CATEGORY,CODE,CONNECTIONTYPE,CONNECTIONSPID,CONNECTIONID,ISLOBSINCLUDED,ISMOREDATAPENDING,ROWSAFFECTED,ROWSIZE,ROWSPERFETCH,ISSELECTEDFORUPDATE,ISSTARTEDWITHINTRANSACTION,STATEMENTTYPE,STATEMENTID,STATEMENTREUSECOUNT,DETAILTYPE,CREATEDDATE,CREATEDTIME,CREATEDBY,DATAAREAID,RECID) VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?
Object Server EGO_WORK: The database reported (session 81 (152)): [Microsoft Business Solutions-Axapta] Unable to retrieve message for retval -1, ODBC call reason
code 100,
SQLSTATE = []
Error message []. The SQL statement was: "SELECT A.HRMORGANIZATIONID,A.HRMPOSITIONID,A.STARTDATE,A.ENDDATE,A.HRMVIRTUALNETWORKID,A.EMPLOYMENTFACTOR,A.RESIGNREASONCODEID,A.RECID,B.HRMVIRTUALNETWORKID,B.REFERENCETYPE,B.REFERENCE,B.MARITALSTATUS,B.GENDER,B.PERSONNUMBER,B.CITIZENSHIP,B.VISA,B.VISAENDDATE,B.LABOURPERMITENDDATE,B.COMPETENCESEARCHING,B.MOTHERTONGUE,B.HRMCOMPENTENCEREASONCODE,B.USERID,B.LABOURPERMIT,B.NOTESINTERNAL,B.NOTESEXTERNAL,B.RECID,C.EMPLID,C.NAME,C.DIMENSION,C.DIMENSION2_,C.DIMENSION3_,C.DIMENSION4_,C.TRAINING,C.ADDRESS,C.PHONE,C.PHONELOCAL,C.USERID,C.ALTNUM,C.ZIPCODEID,C.COUNTRYID,C.STATEID,C.COUNTYID,C.URL,C.EMAIL,C.TELEX,C.CELLULARPHONE,C.TELEFAX,C.CALENDARID,C.BIRTHDATE,C.ALIAS,C.ITEMBUYERGROUPID,C.CITY,C.STREET,C.PAGER,C.SMS,C.TITLE,C.REFZIPCODE,C.RESIGNREASONCODEID,C.SENIORITYDATE,C.OUTLOOKUSERID,C.DATELASTSYNCWITHOUTLOOK,C.SYNCINTERVAL,C.TIMELASTSYNCWITHOUTLOOK,C.SYNCWITHOUTLOOK,C.HRMABSENCESETUPID,C.ABSENCEFROMDATE,C.WORKINGHOURS,C.WORKINGHOURS2_,C.WORKINGHOURS3_,C.WORKINGHOURS4_,C.WORKINGHOURS5_,C.WORKINGHOURS6_,C.WORKINGHOURS7_,C.PROBATIONDATE,C.EMPLOYEETERMINATIONNOTICEUNIT,C.EMPLOYERTERMINATIONNOTICEUNIT,C.EMPLOYERTERMINATIONNOTICE,C.EMPLOYEETERMINATIONNOTICE,C.PENSIONSTARTDATEEMPLCONTRACT,C.PENSIONSTARTDATEEMPL,C.CURRENCY,C.HRMINCOMETAXCATEGORYID,C.HRMINCOMETAXCODEID,C.EMPLOYERSAVINGAMOUNT,C.EMPLOYEESAVINGAMOUNT,C.HOLIDAYS,C.VACATIONPAYMENT,C.MOVINGALLOWANCEAMOUNT,C.FIRSTNAME,C.MIDDLENAME,C.LASTNAME,C.SALUTATION,C.NAMESUFFIX,C.INTERNALEXTERNAL,C.EMAILSAVECOPY,C.STATUS,C.HRMUNIONIDNEGOTIATOR,C.HRMUNIONID,C.HRMSALARYTYPE,C.HRMSALARYSCALEDATE,C.HRMACTIVEINACTIVE,C.HRMVACATIONWITHSALARY,C.HRMDAYSOFFWITHSALARY,C.HRMCAREWITHSALARY,C.HRMSALARYSENIORITYDATE,C.ACTIVITYREMINDERMINUTES,C.SMMSYNCHRONIZEDAYSBACK,C.SMMSYNCHRONIZEDAYSFORWARD,C.PAYFORMTYPE_RU,C.PAYEMPLOYMENTDATE_RU,C.PAYRESIGNEDDATE_RU,C.PAYCALENDARID_RU,C.PAYBLOCKEDFROM_RU,C.PAYBLOCKED_RU,C.PAYINN_RU,C.PAYGNICODE_RU,C.PAYINNPF_RU,C.PAYMAINEMPLID_RU,C.PAYBANKPAYMENT_RU,C.ESTATE_RU,C.BUILDING_RU,C.FLAT_RU,C.STREETID_RU,C.SETTLEMENTID_RU,C.TOWNID_RU,C.IDENTITYCARDCODE_RU,C.IDENTITYCARDNUMBER_RU,C.RPAYHRMORGANISTIONID,C.EMPLGROUPID_RU,C.RHRMCREATEDATE,C.RHRMKINDOFWORK,C.RHRMTERMDATE,C.RHRMSORTOFWORK,C.IDENTITYCARDISSUEBY_RU,C.IDENTITYCARDISSUEDATE_RU,C.RHRMTRADEUNIONIST,C.RHRMEDUCATIONTYPEID,C.RHRMSCIENTIFICWORK,C.RHRMINVENTIONS,C.RHRMSTENOGRAPHY,C.RHRMCOMPUTERSKILL,C.RHRMTYPEWRITERSKILL,C.RHRMNATIONALITYID,C.RHRMINRESERVE,C.RHRMPENSIONER,C.RHRMDRIVINGLICENCE,C.RHRMZIPCODEFACTID,C.RHRMCOUNTRYFACTID,C.RHRMBUILDINGFACT,C.RHRMFLATFACT,C.RHRMSTREETFACTID,C.RHRMCOUNTRYBIRTHID,C.RHRMSTATEBIRTH,C.RHRMSTATEFACTID,C.RHRMCOUNTYBIRTH,C.RHRMCOUNTYFACTID,C.RHRMSETTLEMENTFACTID,C.RHRMTOWNBIRTH,C.RHRMTOWNFACTID,C.RHRMESTATEFACT,C.RHRMMILITARYSERVICE,C.RHRMMOBILIZATION,C.RHRMMILITARYRANK,C.RHRMMILITARYSPECIALITY,C.RHRMMILITARYSERVICEABLEBODIED,C.RHRMMILITARYREGISTRATION,C.RHRMMILITARYSPECIALREGIST16062,C.RHRMMILITARYTAKEOFFREGISTER,C.RHRMMILITARYCATEGORY,C.RHRMMILITARYGROUP,C.RHRMLABOURCONTRACTDATE,C.RHRMLABOURCONTRACT,C.RHRMADDRESSFACT,C.IDENTITYCARDSERIES_RU,C.RHRMCONTINUITYDATETEXT,C.RHRMSPECIALITYDATETEXT,C.RHRMUNHEALTHYSENIORITYDATETEXT,C.RHRMNORTHSENIORITYDATETEXT,C.RHRMSENIORITYDATETEXT,C.RHRMMILITARYCONSCRIPT,C.RHRMMILITARYRESERVED,C.RHRMPERSONNELCATEGORY,C.RHRMBIRTHPLACETYPE,C.ADVHOLDER_RU,C.RHRMCITYFACT,C.RHRMSTREETFACT,C.CPA_QUALIFICATIONLEVEL,C.CPA_POSTINGACCOUNTNUM,C.CPA_POSTINGOFFSETACCOUNT,C.CPA_POSTINGPROFILE,C.CPA_POSTINGOFFSETPROFILE,C.CPA_POSTINGDIMENSIONPROFILE,C.EGO_ASSISTENT,C.EGO_BANKACCOUNTNUM,C.EGO_HISTORICALKEY,C.EGO_TMPBANKACCOUNTID,C.EGO_ASSISTENT1,C.EGO_WORKPERMISSION,C.EGO_INTEMPLID,C.EGO_INTCOMPANYID,C.EGO_INTEMPLNAME,C.EGO_CURRENTEMPLBANKACCOUNTID,C.EGO_REGSTREET,C.EGO_REGZIPCODEID,C.EGO_REGCOUNTRYID,C.EGO_REGSTATEID,C.EGO_REGCITY,C.EGO_REGCOUNTYID,C.EGO_REGTOWNID_RU,C.EGO_REGSETTLEMENTID_RU,C.EGO_REGSTREETID_RU,C.EGO_REGESTATE_RU,C.EGO_REGBUILDING_RU,C.EGO_REGFLAT_RU,C.EGO_REGADDRESS,C.EGO_DRIVINGLICENSENUMBER,C.EGO_DRIVINGLICENSECATEGORY,C.EGO_REGION,C.EGO_CHECKDATE,C.EGO_CHECKRESPONSIBLE,C.EGO_SEX,C.EGO_EXTCOMPANY,C.EGO_ROOM,C.RECID,C.EGO_CHECKRESULT FROM HRMVIRTUALNETWORKHISTORY A,HRMVIRTUALNETWORKTABLE B,EMPLTABLE C WHERE ((A.DATAAREAID='эго') AND (((((A.STARTDATE>={ts '2007-06-01 00:00:00.000'}) AND (A.STARTDATE<={ts '2007-06-30 00:00:00.000'})) OR ((A.ENDDATE>={ts '2007-06-01 00:00:00.000'}) AND (A.ENDDATE<={ts '2007-06-30 00:00:00.000'}))) OR (((A.ENDDATE={ts '1900-01-01 00:00:00.000'}) OR (A.ENDDATE>={ts '2007-06-30 00:00:00.000'})) AND (A.STARTDATE<={ts '2007-06-30 00:00:00.000'}))) AND (A.HRMPOSITIONID='31000'))) AND ((B.DATAAREAID='эго') AND (A.HRMVIRTUALNETWORKID=B.HRMVIRTUALNETWORKID)) AND ((C.DATAAREAID='эго') AND (B.REFERENCE=C.EMPLID)) ORDER BY A.DATAAREAID,A.HRMVIRTUALNETWORKID,A.HRMORGANIZATIONID,A.STARTDATE,A.HRMPOSITIONID OPTION(FAST 1)"
Object Server EGO_WORK: User 10028 (wait w/o response in session 75, thread 0xd78) disconnected abnormally
Не подскажите, что может быть?
Старый 04.07.2007, 19:22   #2
vesna dba is offline
vesna dba
Буквально пару дней назад у меня такие ошибки были на сервере с AOS. Появились на ровном месте. Еще были ошибки на тему ".. ошибка драйвера ODBC ..".
После рестарта сервера ошибки ушли. (Windows Server 2003 R2 Std RU SP1).
Причину появления ошибки не выяснили.
Axapta 3.0 CIS SP3 CU1
Народу собралось - яблоку плюнуть негде!
Старый 04.07.2007, 20:25   #3
Kozerog is offline
Kozerog
У нас рестартом серверов не проблема не лечится. Переставили АОС для сервер БД для эксперимента - не помогло, кол-во выключений системы стало меньше, но проблема не решается.
Старый 04.07.2007, 21:28   #4
vesna dba
как у вас AOS к БД цепляется? через ODBC или без него? Аксапта 3.0 у вас надеюсь.
После чего\после каких изменений настроек начались эти ошибки?
Старый 09.07.2007, 15:29   #5
somebody is offline
somebody
(Пере)установите самый свежий MDAC.
После на всякий случай пересоздайте ODBC-источник, соблюдая рекомендации мануала (опции).
Старый 01.02.2013, 09:52   #6
_AxDevel_ is offline
_AxDevel_
Сообщение от Kozerog Посмотреть сообщение
code 100,
SQLSTATE = []
Подскажите, в как решили вопрос, в чём была проблема?
У меня DAX 4.0: kernel 4.0.2503.27 , application 4.0.2501.121. Заметил, что "Unable to retrieve message for retval -1, ODBC call reason code 100" возникает в ситуации, когда AOS занимает много памяти, более 2ГБ.
ax3.0
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
После установки KR2 на AX3 SP3 не пускает на AOS больше 100 пользователей Alexandr A. Osipkin DAX: Администрирование 14 06.12.2008 02:33
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
DynamicsTech: What's New in Dynamics Ax 4.0 AOS? Blog bot DAX Blogs 0 12.04.2007 11:50
axaptapedia: Control AOS from command line Blog bot DAX Blogs 0 09.03.2007 14:50
Часовой пояс GMT +3, время: 22:33.
