Старый 30.08.2007, 04:41   #1
Issues concerning X++: Correction guide - Compiler warnings
Источник: http://blogs.msdn.com/x/archive/2007...-warnings.aspx
The following is based on material kindly provided by Michael Fruergaard Pontoppidan. I have edited it substantially and added some new material to make it fit within the context of this blog.
Introduction
This guide will show you how to resolve compiler warnings in Axapta.
Compiler warnings are a strong indication that the code contains flaws or questionable constructs. The compiler groups the warnings in several levels according to the warning's severity: Level 1 is for very questionable issues, downto level 4 which are smaller issues. All compiler warnings must all be eliminated from production code to improve the overall code quality.
Note that the Dynamics Ax development environment also features a best practise framework that diagnoses the code's adherence to the established best practises. The diagnostics issued by this tool are not covered here. Contents
Introduction.
Compiler Warnings Level 1.
Break statement found outside legal context.
The new method of a derived class does not call super().
The new method of a derived class may not call super().
Function never returns a value.
Not all paths return a value.
Assignment/Comparison loses precision.
Compiler Warnings Level 2.
Unreachable code.
Compiler Warnings Level 3.
Empty compound statement.
Updating Views is not supported.
Compiler Warnings Level 4.
Class names should start with an uppercase letter.
Member names should start with a lowercase letter.
Break statements are used to skip to the end of for, while, do-while and switch statements. If a break statement is encountered outside the body of one of these statements it is ignored at runtime and should be removed from the code to avoid confusion and improve legibility.
Example
1: { 2: int i; 3: 4: for (i = 1; i
X++: Is the X++ Compiler Too Flexible? Blog bot DAX Blogs 17 03.03.2009 17:11
axStart: Why performance issues hits you’re AX implementation 3 months after going live. Blog bot DAX Blogs 0 05.03.2008 05:47
Issues concerning X++: Macros - Definitions and Pitfalls Blog bot DAX Blogs 0 15.11.2007 09:20
Dynamics AX: Microsoft Dynamics AX (DAX): Known Issues when upgrading to Microsoft Dynamics™ AX 4.0 - Arijit Basu | AX MVP Blog bot DAX Blogs 0 31.05.2007 03:30
Arijit Basu: Known Issues when upgrading to Microsoft Dynamics™ AX 4.0 Blog bot DAX Blogs 0 29.05.2007 15:10
Часовой пояс GMT +3, время: 21:51.
