Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 14.11.2007, 11:51   #1
ist is offline
ist
Problem with inherited RunBase class
Hi,
First I apopogize for my english.
The my problem is:
I have class "Class1"inheritor of RunBase.In this class I have overrided dialog(), getFromDialog() and Init() methods.I have other class "Class2"who inherited mentioned above Class1.In second class I have overrided pack() and unpack() methods.When I have two instantions of "Class2" I do not close first instantion while second is opened.
How I resolve this problem?
Thank's you in advance.
Class1:
class Class1 extends RunBase
    NoYes checkThing;
    DialogField dialogCheckThing;
protected Object dialog()
    DialogRunBase dialog;
    dialog = super();
    dialogCheckThing = dialog.addFieldValue(typeid(NoYes), checkThing);
    return dialog;
public boolean getFromDialog()
    boolean ret;
    ret = super();
    checkThing = dialogCheckThing.value();
    return ret;
Class2:
class Class2 extends Class1
    #define.CurrentVersion(1)
    #localmacro.CurrentList
        checkThing
    #endmacro
public container pack()
    return [#CurrentVersion, #CurrentList];
public boolean unpack(container packedClass)
    boolean         _ret = false;
    Integer         _version    = conPeek(packedClass,1);
    switch (_version)
        case #CurrentVersion:
            [_version, #CurrentList] = packedClass;
            _ret = true;
            break;
    return _ret;
public void run()
    super();
    this.prompt();
public static void main(Args args)
    Class2 class2 = new Class2();
    if(class2.init())
        class2.run();
Последний раз редактировалось ist; 14.11.2007 в 14:49.
Старый 17.11.2007, 10:25   #2
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 646 (26) +++++++
Could you please explain your problem once again? It's not quite clear.
Старый 16.05.2008, 00:10   #3
axstart is offline
axstart
MVP
16 / 10 (1) +
you must also define the macro in class1 + pack + unpack
look at the next link for more details
http://axstart.spaces.live.com/blog/...C0A0!292.entry
runbase
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Inside Dynamics AX 4.0: RunBase Framework Extension Part IV Blog bot DAX Blogs 0 02.10.2007 04:49
Inside Dynamics AX 4.0: RunBase Framework Extension Part I Blog bot DAX Blogs 0 30.09.2007 09:20
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 14:22.
