Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 13.12.2007, 07:55   #1
tangolp is offline
tangolp
Angry grid question
How can I detect the value of the grid item when the user click on a row? For example, I have a grid where the datasource is the SalesLine table. Id' like to get the Linenum when the user clicks on a row. Can someone help?
Thanks!
Старый 13.12.2007, 10:26   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
The method active is called on the datasource each time you select a row in the grid.
You can override this method and just use the SalesLine.LineNum field from the table.
SalesLine will, at this point, contain the selected row
Старый 13.12.2007, 21:32   #3
tangolp is offline
tangolp
Thank you for your reply. When click on a different record, it always return line 1.
public int active()
int ret;
ret = super();
element.design().caption(int2str(salesLine.LineNum));
return ret;
Thanks!
axaptapedia: Filter-by-Grid Blog bot DAX Blogs 2 30.05.2012 13:39
Dynamics AX: DAX 4.0 Filter by Grid [Update] Blog bot DAX Blogs 0 27.04.2007 17:10
Advanced programming: Grid data and view manipulations batiskaf_new DAX: Программирование 15 21.06.2006 11:44
Сохранение настроек GRID (ширина и порядок колонок) liza DAX: Программирование 1 25.07.2003 22:20
Часовой пояс GMT +3, время: 01:28.
