Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 14.12.2007, 02:11   #1
Sveta1978 is offline
Sveta1978
referencing grid columns, finding selected records
i have a grid. in the grid i have lines of data. how do i reference the particular columns in the grid to perform some calculations? Also, how do i tell when and what records are selected? datasource is a TEMPORARY table. as soon as records load, the table is blank...
its the DAX 4.0
Inventory Management --> Periodic --> Sales Release Order Picking screen
sales lines grid
Thank you!
Последний раз редактировалось Sveta1978; 14.12.2007 в 18:52.
Старый 14.12.2007, 14:45   #2
Russland is offline
Russland
Аватар для Russland
267 / 116 (4) +++++
Look at these lines as an example:
for (InventTable = InventTable_ds.getFirst(1); InventTable.ItemId; InventTable = InventTable_ds.getNext())
В глухомани, в лесу Несмотря на красу Дни проводит Лиса Патрикевна. Я никак не пойму Отчего, почему Не пускают куму На деревню
Старый 14.12.2007, 17:04   #3
DreamCreator is offline
DreamCreator
Аватар для DreamCreator
Axapta Retail User
553 / 45 (3) +++
    // Another example working with Form Data Source
InventTable     inventTable;
FormDataSource  fds;
Common          common;
fds inventTable.dataSource();
    if (
fds.anyMarked())
inventTable fds.getFirst(1);
        while (
inventTable)
// do something with cursor InventTable
    else
inventTable fds.cursor();
// refresh datasource
common fds.cursor().data();
fds.research();
fds.findRecord(common);
fds.refresh();
Старый 14.12.2007, 18:54   #4
Sveta1978
Одна проблема
DataSource of the grid from which data is being dragged is temporary.... it is not stored in the database...
Старый 15.12.2007, 15:19   #5
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 645 (26) +++++++
Sveta, both of the above examples doesn't imply that the table is stored in database. Hence they are absolutely compliant with your requirements.
However could you please specify what kind of calculations you would like to perform? This might help us to give you a better answer.
axaptapedia: Filter-by-Grid Blog bot DAX Blogs 2 30.05.2012 13:39
Dynamics AX: DAX 4.0 Filter by Grid [Update] Blog bot DAX Blogs 0 27.04.2007 17:10
Axapta Lessons: Merge Customer Records Blog bot DAX Blogs 0 28.10.2006 18:22
Advanced programming: Grid data and view manipulations batiskaf_new DAX: Программирование 15 21.06.2006 11:44
Часовой пояс GMT +3, время: 20:34.
