Старый 22.02.2008, 17:37   #1
25,751 / 851 (80) +++++++
mfp: Upgrading to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009 @ Convergence 2008
Источник: http://blogs.msdn.com/mfp/archive/20...ence-2008.aspx
Deepak Kumar and myself will be hosting a session on the upgrade process at Convergence in Orlando next month. I hope to see you there.
Upgrading to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009; 3/13/2008 10:00AM-11:00AM; W204
This session will take you through the end-to-end flow of upgrading from Microsoft Dynamics AX 3.0 to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009. You will see an overview of the code upgrade as well as the data upgrade process along with recommended best practices. Examples of the improved upgrade documentation, with a focus on the implementation guidelines that come with a dedicated section for upgrade, will also be covered. This session will also include tips on performing data upgrade and code upgrade more efficiently and effectively. Additionally, you'll learn tips on the extra steps needed to upgrade if you've extended your solution. This session is designed for partners and customers who are planning to upgrade or would like to learn more about a Microsoft Dynamics AX upgrade.
Часовой пояс GMT +3, время: 05:07.
