#1 |
условие where по полям одной и той же таблицы
Добрый день.
С чем может быть связано, что вот такой код не работает нормально X++: static void Job1(Args _args) { InventTable inventTable; ; while select inventTable where inventTable.ItemId == inventTable.TST_PriceItemId { print inventTable.ItemId; } pause; } Если написть так X++: static void Job1(Args _args) { InventTable inventTable; ; while select inventTable { if(inventTable.ItemId == inventTable.TST_PriceItemId) print inventTable.ItemId; } pause; } |
#2 |
упс, забыл
DAX 40 SP2EE |
#3 |
А какой SQL генерится?
#4 |
вот такой:
Код: Оператор SQL: (InventTable) SELECT A.ITEMGROUPID,A.ITEMID,A.ITEMNAME,A.ITEMTYPE,A.PURCHMODEL,A.HEIGHT,A.WIDTH,A.SALESMODEL,A.DEL_COSTGROUPID,A.REQGROUPID,A.EPCMANAGER,A.PRIMARYVENDORID,A.NETWEIGHT,A.DEPTH,A.UNITVOLUME,A.BOMUNITID,A.DENSITY,A.DIMENSION,A.DIMENSION2_,A.DIMENSION3_,A.COSTMODEL,A.USEALTITEMID,A.ALTITEMID,A.PRODFLUSHINGPRINCIP,A.PBAITEMAUTOGENERATED,A.BOMMANUALRECEIPT,A.STOPEXPLODE,A.PHANTOM,A.BOMLEVEL,A.BATCHNUMGROUPID,A.AUTOREPORTFINISHED,A.ALTCONFIGID,A.STANDARDCONFIGID,A.PRODPOOLID,A.PROPERTYID,A.ABCTIEUP,A.ABCREVENUE,A.ABCVALUE,A.ABCCONTRIBUTIONMARGIN,A.COMMISSIONGROUPID,A.CONFIGURABLE,A.SALESPERCENTMARKUP,A.SALESCONTRIBUTIONRATIO,A.SALESPRICEMODELBASIC,A.MINAVERAGESETTLE,A.NAMEALIAS,A.PRODGROUPID,A.PROJCATEGORYID,A.GROSSDEPTH,A.GROSSWIDTH,A.GROSSHEIGHT,A.STANDARDPALLETQUANTITY,A.QTYPERLAYER,A.SORTCODE,A.CONFIGSIMILAR,A.SERIALNUMGROUPID,A.DIMGROUPID,A.MODELGROUPID,A.ITEMBUYERGROUPID,A.TAXPACKAGINGQTY,A.WMSPALLETTYPEID,A.DEL_STOPEXPLODEPRICE,A.WMSPICKINGQTYTIME,A.TARAWEIGHT,A.SCRAPVAR,A.SCRAPCONST,A.STANDARDINVENTCOLORID,A.STANDARDINVENTSIZEID,A.ITEMDIMCOMBINATIONAUTOCREATE,A.ITEMDIMCOSTPRICE,A.ITEMIDCOMPANY,A.ALTINVENTSIZEID,A.ALTINVENTCOLORID,A.FORECASTDMPINCLUDE,A.BOMCALCGROUPID,A.PBAITEMCONFIGURABLE,A.PBAINVENTITEMGROUPID,A.PBAHIDEDIALOG,A.PBAHIDEAPPROVAL,A.PBAAUTOSTART,A.PBAMANDATORYCONFIG,A.PACKING_RU,A.ASSETGROUPID_RU,A.ASSETID_RU,A.HMK_ITEMDOCUMENT,A.HMK_TEMPERATURETO,A.HMK_TEMPERATUREFROM,A.HMK_LENGTHOFSALES,A.HMK_TERMOFSALES,A.HMK_DATEOFPROD,A.HMK_GOODGROUPID,A.HMK_PRICEITEMID,A.RECVERSION,A.RECID FROM INVENTTABLE A WITH( INDEX(I_175ITEMIDX)) WHERE ((DATAAREAID=?) AND (ITEMID=HMK_PRICEITEMID)) [Код=92, Использовано повторно=Нет] |
#5 |
Мутно. А чего поле называется TST_PriceItemId в коде и HMK_PriceITEMID в TSQL?
Я проверил на выполнение на 2 полях (ItemGroupId & ModelGroupId) Работает и тот джоб, и тот. (на AX 5) |
#6 |
![]() У коллеги моего тоже все работает. От чего это зависит, я понять не могу. Думал, может, конфигурационные утилиты не так настроены, опять же у коллеги такие же как у меня. но результат другой. |
#7 |
SQL правильный. Как он норабатывает в Менеджемент Студио?
#8 |
Еще: при сравнении аксапта не учитывает регистр символов. Может ли так быть настроен SQL, что он это учитывает по другому?
| За это сообщение автора поблагодарили: Starling (1). | |
#9 |
В студии отрабатывает корректно.
Регистр не имеет значения т.к. коды номенклатуры цифровые.
С уважением, kvan. |
#10 |
Поигрался с запросами
Следующий код отрабатывает правильно X++: while select ItemId, TST_PriceItemId from inventTable where inventTable.TST_PriceItemId == inventTable.ItemId { info(inventTable.ItemId); } Код: SELECT A.ITEMID,A.TST_PRICEITEMID,A.RECID FROM INVENTTABLE A WHERE ((DATAAREAID=?) AND (TST_PRICEITEMID=ITEMID)) X++: while select ItemId, TST_PriceItemId from inventTable where inventTable.ItemId == inventTable.TST_PriceItemId { info(inventTable.ItemId); } Код: SELECT A.ITEMGROUPID, ...(перечень всех полей), A.RECID FROM INVENTTABLE A WHERE ((DATAAREAID=?) AND (ITEMID=TST_PRICEITEMID))
#11 |
| За это сообщение автора поблагодарили: Kabardian (2). | |
#12 |
Попобробуйте добавить условие && InventTable.recID
#13 |
Угу.
Помимо того, что выдергивает все поля, такое впечатление, что где-то внутри "взводит" firstonly для такого запроса. Очень похоже по обмену с б/д. Как вариант, можно еще сделать группировку по нужным полям
Axapta v.3.0 sp5 kr2 |
#14 |
Добавил не RecId, а поле с которым сравниваю (TST_PriceItemId) и все работает как нужно
X++: while select ItemId, TST_PriceItemId from inventTable where inventTable.TST_PriceItemId && inventTable.ItemId == inventTable.TST_PriceItemId { info(inventTable.ItemId); } А если такое выскочит где нить в стандарте? (Сразу скажу что стандартный код на предмет наличия таких запросов не изучал)
#15 |
В том то и дело. Поэтому и пытаемся понять - может где то не так что то настроено или какие нибудь хинты или еще чего включены\ выключены.
#16 |
Создал новую таблицу. Написал для нее такой же Job. Получил корректный результат.
Кажется, начинаю догадываться, в чем проблема. При импорте данных система ругалась на ID 50008. Сразу не стал разбираться, в чем бок. Посмотрел на поле TST_PriceItemId его ID 50008. Щас повторю импорт и посмотрю точное сообщение. |
#17 |
Повторный импорт к возникновению сообщения об оштибке не приводит.
Но проблема все таки не в поле TST_PriceItemId. Перенес значение из этого поля в другое - стандартное. Результат такой же. |
#18 |
Судя по всему глюк кеша
#19 |
#20 |
Это бага кеша, None в некоторых аспектах действует как Found (см ссылку, которую ранее приводил)
