Старый 09.04.2008, 20:05   #1
gatesasbait: Compile forward from code
Источник: http://gatesasbait.spaces.live.com/B...B9F5!204.entry
Good morning,
Here is an X++ snippet showing how to compile forward a class without using the context menu. It potentially bypasses developper licenses, not sure about that though.
public static void CompileFormletter(Args _args)
    SysCompilerOutput::compileForward(className2Id("Formletter"));
Dynamics AX: Microsoft Dynamics AX EP Team Blog - Filtering a DataSet from Code behind Blog bot DAX Blogs 0 04.12.2008 03:07
gatesasbait: Code code to generate code in Dynamics AX Blog bot DAX Blogs 0 31.07.2008 22:05
gatesasbait: Automatic creation of a PDF from a customer invoice in Dynamics Ax 4.0 Blog bot DAX Blogs 0 28.04.2008 19:05
axStart: Starting the code profiler from code Blog bot DAX Blogs 0 17.03.2008 15:05
Часовой пояс GMT +3, время: 02:59.
