Старый 27.05.2008, 14:05   #1
25,643 / 848 (80) +++++++
palleagermark: Transform a date into a number of months from a specific offset date
Источник: http://palleagermark.blogspot.com/20...of-months.html
Here is a small algorithm to transform a date into a number of months from a base date. You can for example use this if you need to create a report with numbers places in a column per month starting with the month of a specific date.
The algorithm to transform the date into a month is this:
if (columDate < dateEndYr(offSetDate))
    column = mthOfYr(columDate) - mthOfYr(offSetDate) + 1;
else
    column = 12 - mthOfYr(offSetDate) + mthOfYr(columDate) +1;
And here is a job to illustrate the useage:
static void date2Column(Args _args)
    Date offsetdate;
    Date columDate;
    int column;
    int counter;
    offSetDate = 30\09\2008;
    columDate = offSetDate;
    while (counter <= 11)
        counter++;
        // The actual algorithm -->
        else
        // The actual algorithm <--
        print strFmt("Date: %1 Month: %2", columDate, column);
        columDate = dateMthFwd(columDate, 1);
    pause;
palleagermark: Creating an image file based on plain text from AX Blog bot DAX Blogs 0 03.03.2009 03:08
palleagermark: Channel 9 video: Dynamics AX Version Control interview from Convergence in Copenhagen 2008 Blog bot DAX Blogs 0 30.01.2009 16:05
axaptapedia: Packing date range values in queries Blog bot DAX Blogs 1 09.11.2007 13:10
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 07:45.
