Старый 31.07.2008, 22:05   #1
axStart: A structure way off dealing with garbage collection & memory leaks with the Dynamics AX .net connector.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!364.entry
When reading the article on Debugging X++ Object Leaks on the weblog of the Dynamics Ax Performance team. I really start worrying about this issue. The writhers in this article tell us that each AxaptaObject and AxaptaTable must have a dispose called on it before going out of scope, or we’ll leak the object on the server with no way to clean it up.
There is one quite easy rule for this issue. The object that creates an object should also dispose it. Disposing can happen on 2 ways, by the garbage collector or by your code. The last one we have in control. But how do we tell the garbage collector to clean up also my AxaptaObject and AxaptaTable.
Solution:
We create a wrapper class for the AxaptaObject and the AxaptaTable. This wrapper class will implement also the IDisposable interface.
publicclassAXCommon : IDisposable
        publicAxaptaRecord iAxObject;
        privatebool disposed = false;
        publicAxaptaRecord common
            get
                return iAxObject;
            set
                iAxObject = value;
        publicvoid Dispose()
            Dispose(true);
        privatevoid Dispose(bool disposing)
            // Check to see if Dispose has already been called.
            if (!this.disposed)
                // If disposing equals true, dispose all managed and unmanaged resources.
                if (disposing)
                    // Dispose managed resources.
                    iAxObject.Dispose();
                disposed = true;
By the way, it is quite handy to implement additional general functions in this wrapper class. Think like all the sysdictTable functionality and other general table functionality
public System.Int32 TableID()
   try
      return (System.Int32)iAxObject.get_Field("TableId");
   catch (Exception ex)
      throw ex;
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
ALEG: Проект "Фишка недели" и первый пост - Microsoft Dynamics™ AX .NET Business Connector Blog bot DAX Blogs 1 22.11.2006 09:43
Часовой пояс GMT +3, время: 04:15.
