Старый 10.12.2008, 14:05   #1
axStart: Get your forms back in one workspace
Источник: http://axstart.spaces.live.com/Blog/...C0A0!434.entry
In AX 4.0 all forms appear in the main AX application Frame, but with AX 2009 all your forms are hovering around acting like independent applications Forms. If you close the main AX window by accident, all Forms are gone. It is not so hard to get the AX 4.0 look and feel back in AX 2009. Every form has a design property WindowType. Change this properly to Workspace and  the Form will have similar behavior like AX 4.0.
A more general solution for this issue will be the next option:
·         Add labels to Base Enum FormWindowType.
·         Add the base enum  FormWindowType to Table SysUserInfo
·         Add the next line before super() in the method init of the Class SysSetupFormRun
public void init()
    if(this.form().design().windowType() == FormWindowType::Standard)         //AXStart
        this.form().design().windowType(SysUserInfo::find().FormWindowType);  //AXStart
    super();
    SysSecurityFormSetup::loadSecurity(this);
    this.dimensionFieldCtrls();
    this.inventStorageDimFieldCtrls();
    if (this.isWorkflowEnabled())
        workflowControls = SysWorkflowFormControls::construct(this);
        workflowControls.initControls();
За это сообщение автора поблагодарили: gl00mie (5), alex55 (1).
AIFFault class AX2009 get all errors back in webservice call axstart DAX in English 0 28.01.2009 19:02
axStart: Please keep the AOT reports in Dynamics AX next release alive Blog bot DAX Blogs 2 13.12.2008 12:18
X++: Using graphics in forms and legacy reports. Blog bot DAX Blogs 0 01.05.2008 05:20
Часовой пояс GMT +3, время: 12:28.
