Старый 23.12.2008, 20:24   #1
AndrianG is offline
AndrianG
Как програмно поймать клик на кнопке ?
Есть такой код Job :
static void ag_createFormControl(Args _args)
    Args args;
    Form form;
    FormRun formRun;
    FormBuildDesign formBuildDesign;
    FormBuildDataSource formBuildDataSource;
    FormBuildGridControl formBuildGridControl;
    FormBuildStringControl formBuildStringControl;
    FormStringControl formStringControl;
    FormGridControl formGridControl;
    formBuildCommandButtonControl formBuildCommandButtonControl;
    formButtoncontrol formbuttoncontrol;
    DictTable dictTable;
    int idx;
    int idx2;
    int idx3;
    // Create the form header.
    form = new Form();
    // Add data sources to the form.
    dictTable = new DictTable(tablenum(CustTable));
    formBuildDataSource = form.addDataSource(dictTable.name());
    formBuildDataSource.table(dictTable.id());
    // Create the form design.
    formBuildDesign = form.addDesign("Design");
    // Add controls.
    formBuildGridControl =
 formBuildDesign.addControl(FormControlType::Grid, "Table Grid");
    formBuildGridControl.dataSource(dictTable.name());
    idx = formBuildGridControl.id();
    formBuildStringControl =
 formBuildDesign.addControl(FormControlType::String, "Table String");
    formBuildStringControl.dataSource(dictTable.name());
    idx2 = formBuildStringControl.id();
  formbuildcommandbuttoncontrol=formbuilddesign.addControl(formcontroltype::CommandButton,"OK");
  formbuildcommandbuttoncontrol.text('&OK');
  idx3=formbuildcommandbuttoncontrol.id();
    // Add data fields to the controls.
    formBuildGridControl.addDataField(formBuildDataSource.id(),
dictTable.fieldName2Id("AccountNum"));
dictTable.fieldName2Id("Phone"));
    formBuildStringControl.dataSource(formBuildDataSource.id());
    formBuildStringControl.dataField(1);
    args = new Args();
    args.object(form);
    // Create the run-time form.
    formRun = new FormRun(args);
    formRun.run();
    //    formrun.controlMethodOverloadObject(formbuttoncontrol);
  //      formbuttoncontrol=new formbuttoncontrol();
    //    formbuttoncontrol=formrun.controlMethodOverloadObject(formbuttoncontrol);
//       formbuttoncontrol=formrun.controlCallingMethod();
         formButtonControl = formRun.control(idx3);
         formbuttoncontrol.clicked();
    formRun.detach();
    // Select the grid control.
    formGridControl = formRun.control(idx);
    formGridControl = formRun.selectTarget(formGridControl);
    formGridControl.showColLabels(false);
Междк коментариев //------------------------------------------------------------------ есть код который якобы работает с formbuttoncontrol.clicked(); но не получаестя поймать этот клик ка быть ?
Старый 23.12.2008, 21:26   #2
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Это что вообще было? Вам точно на этот форум?
Старый 23.12.2008, 22:20   #3
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Судя по остальным постам Андриана - это по идее должно было быть опубликовано в ветке Dynamics Ax.
Старый 24.12.2008, 07:59   #4
перенес.
Старый 24.12.2008, 09:11   #5
Lucky13 is offline
Lucky13
714 / 198 (8) ++++++
Ничего не понял, но по-моему должно быть вот так
FormMethodHandler = formMethodHandler = new FormMethodHandler()
formRum.controlMethodOverload(true);
formRun.this.controlMethodOverloadObject(formMethodHandler)
Класс FormMethodHandler будет обрабатывать все события формы. Для этого в нем должны быть методы следующего вида
void MyButton_clicked()
где MyButton - имя контрола, а clicked - имя метода у этого контрола
Старый 24.12.2008, 10:07   #6
George Nordic is offline
George Nordic
Аватар для George Nordic
4,480 / 1255 (50) ++++++++
Записей в блоге: 9
Объясните, зачем Вы создаете динамическую форму?
И копайте в сторону [Tutor]FormRunBase[Batch] - там есть пример, как берется стандартная форма и в нее "пихаются" дополнительные контролы. На стандартной форме можно у баттона перехватить клик. Да, писать код на контроле - плохо! В 4ке даже дебагер не работал.
С Уважением,
Георгий
Старый 24.12.2008, 10:15   #7
AndrianG is offline
AndrianG
->Lucky13
Просто я хотел в run-time создать форму и несколько контролов а потом (в моем примере ) при клике на button что-то происходило ,к примеру, выскакивает сообщение !
Старый 24.12.2008, 10:19   #8
Lucky13 is offline
Lucky13
Сообщение от AndrianG Посмотреть сообщение
Тогда я все правильно понял, сделайте как я указал и все будет работать
Старый 24.12.2008, 10:23   #9
AndrianG is offline
AndrianG
Сообщение от George Nordic Посмотреть сообщение
С Уважением,
Георгий
А ты можеш простой пример показать , который работает !
Старый 24.12.2008, 10:40   #10
AndrianG is offline
AndrianG
Сообщение от Lucky13 Посмотреть сообщение
стандартно класс FormMethhodHandler нету, получается я его должен создать ?
Старый 24.12.2008, 10:43   #11
Lucky13 is offline
Lucky13
Да, класс нужно создать, причем совершенно не важно как он будет называться. Важно как будут называться его методы. Например:
Сработает при клике на кнопке с именем MyButton
Старый 24.12.2008, 10:53   #12
AndrianG is offline
AndrianG
Заработало !
Thank you !
А у меня такой еще вопрос ?
А можно и класс в run-time создать ?
Старый 24.12.2008, 11:01   #13
ZVV is offline
ZVV
MCITP
Oracle
1,006 / 246 (11) ++++++
Да, можно.
Через класс ClassBuild например
Zhirenkov Vitaly
Старый 24.12.2008, 11:06   #14
ZVV is offline
ZVV
MCITP
Oracle
Сообщение от ZVV Посмотреть сообщение
Да, можно.
Хотя стоп, я наверное неправильно понял вопрос. Имелось ввиду чтоб "совсем в рунтайме", без создания класса в АОТ?
Тогда не знаю, не уверен.
А вообще есть замечательная вещь Dialog (с Improvement).
Почему бы вам его не использовать, а не городить весь этот огород, который потом с огнём не разгребёшь и вообще явно всё это не БП.
Zhirenkov Vitaly
Старый 24.12.2008, 13:02   #15
AndrianG is offline
AndrianG
Thumbs up
Получилось проблема решена при помощи Dialog и
formbuildStaticTextControl;
formbuildStaticTextControl formbuildStaticTextControlBold;
formbuildwindowcontrol;
Спасибо за Совет !
Будет нужно попробую и с ClassBuild
Старый 24.12.2008, 13:23   #16
Gustav is offline
Gustav
Аватар для Gustav
SAP
1,858 / 1152 (42) ++++++++
Записей в блоге: 19
Вот Вам еще для коллекции. Можно быстренько переделать джоб в минимально необходимый класс. Т.е. в этом классе должен быть статический метод main (чтобы можно было запускать класс "как джоб" из пунктов меню), а также некоторый основной исполнительный метод (пусть будет run), в который надо практически без изменений поместить код из джоба.
В качестве бонуса за такой переход от джоба к классу будет Вам счастье - Вы сможете код MyButton_clicked поместить в этот же самый класс. А чтобы оперативно менять логику в MyButton_clicked можно воспользоваться функцией runBuf, которой скармливать исполнимый код в зависимости от тех или иных обстоятельств.
Прикладываю демокласс проектом. Для запуска надо написать джоб с одной строчкой: ButtonClickedTestClass::main();
Но всё это всё равно не совсем верный путь, поэтому прислушайтесь к коллегам и по возможности старайтесь избегать подобных динамических наворотов
Тип файла: xpo ButtonClickedTestClass.xpo (2.1 Кб, 437 просмотров)
За это сообщение автора поблагодарили: PMS (1).
Поймать SQL запрос при формировании отчета Qaz Qwerty DAX: Программирование 7 12.06.2008 01:46
как программно поюзать все формы Daido DAX: Программирование 3 02.08.2007 13:39
Создание классов программно Beast-L DAX: Программирование 8 22.11.2006 13:40
Помогите поймать глюк :) db DAX: Программирование 3 02.03.2005 16:09
По нажатию на кнопке в Grid-е появляются... Yuri Safronov DAX: Программирование 3 06.09.2002 11:31
Часовой пояс GMT +3, время: 14:32.
