|  22.01.2009, 12:05 | #1 |
| Участник | palleagermark: Adding simple display fields on VS reports
			Источник: http://palleagermark.blogspot.com/20...lds-on-vs.html ============== One thing I feel is missing from the documentation for AX Visual Studio reports is a simple explanation or demo of how to create an od school display field in a report. I could figure out that a DataMethod was needed but it took me some time to figure out how connect the method with a field on the report and how to pass parameters to the DataMethod. You add a datamethod like this: ... [DataMethod(), AxSessionPermission(SecurityAction.Assert] public static string DataMethod1(string itemId) { string demoString = '(' + itemId + ')'; return demoString; } Then add a field to your design, and in the Expression editor for the field add the code to call your datamethod: =DataMethod1(Fields!ItemId.Value) Источник: http://palleagermark.blogspot.com/20...lds-on-vs.html
				__________________ Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
