Старый 11.02.2009, 06:05   #1
Jim Wang: CRM 4.0: Checkbox style Multi-Select Picklist
Источник: http://jianwang.blogspot.com/2009/01...ti-select.html
CRM 4.0 doesn't have many out-of-box user controls, e.g: a mulit-select picklist. The standard CRM picklist can only save one value in the database, it's not easy to extend this functionality, in addition, you have to deal with the Advanced Find feature.
You can make a picklist multi-selectable by enable the picklist mulitple attribute , e.g: crmForm.all.new_picklist.multiple = true; And then save the selected values somewhere else. However, it does not very impressive the user because the user has to use the CTRL key to select options, which is not user-friendly (Thanks for Alastair Westland (PM @ Parity) who work with me to improve the interface design:)
The script below will draw a checkbox style mulit-select picklist control on the CRM form, and then get options from the real picklist attribute. So how to use it?
1. Create a standard picklist attribute with all options in CRM, put it on the CRM Form. e.g: new_picklist;
2. Create another nvarchar attribute in CRM to save the selected text, put it on the CRM Form and hide the label. e.g: new_picklistvalue;
3. Put the following script in the Form.OnLoad() event.
*NOTE: There is a 'br' flag(var addBr = document.createElement(...) ) just been ignord by blogspot, please replace it when you paste the code!!!
author: Jim Wang @ January 2009
// PL - the picklist attribute; PLV - used to save selected picklist values
var PL = crmForm.all.new_picklist;
var PLV = crmForm.all.new_picklistvalue;
if( PL != null && PLV != null )
PL.style.display = "none";
PLV.style.display = "none";
// Create a DIV container
var addDiv = document.createElement("<div style='overflow-y:auto; height:80px; border:1px #6699cc solid; background-color:#ffffff;' />");
PL.parentNode.appendChild(addDiv);
// Initialise checkbox controls
for( var i = 1; i < PL.options.length; i++ )
var pOption = PL.options[i];
if( !IsChecked( pOption.text ) )
var addInput = document.createElement("" );
else
var addLabel = document.createElement( "");
addLabel.innerText = pOption.text;
var addBr = document.createElement( "
"); //it's a 'br' flag
PL.nextSibling.appendChild(addInput);
PL.nextSibling.appendChild(addLabel);
PL.nextSibling.appendChild(addBr);
// Check if it is selected
function IsChecked( pText )
if(PLV.value != "")
var PLVT = PLV.value.split("||");
for( var i = 0; i < PLVT.length; i++ )
if( PLVT[i] == pText )
return true;
return false;
// Save the selected text, this filed can also be used in Advanced Find
crmForm.attachEvent( "onsave" , OnSave);
function OnSave()
PLV.value = "";
var getInput = PL.nextSibling.getElementsByTagName("input");
for( var i = 0; i < getInput.length; i++ )
if( getInput[i].checked)
PLV.value += getInput[i].nextSibling.innerText + "||";
Jim Wang: Customizing CRM by Using the Microsoft Dynamics CRM Developer Toolkit Blog bot Dynamics CRM: Blogs 0 09.04.2009 22:05
Microsoft Dynamics CRM Team Blog: CRM 4.0: Checkbox style Multi-Select Picklist Blog bot Dynamics CRM: Blogs 0 01.04.2009 05:07
Jim Wang: CRM 4.0 External Connector License Blog bot Dynamics CRM: Blogs 0 11.02.2009 06:05
mscrm4ever: CRM 4.0 Supported Multi Select (Picklist) Control Blog bot Dynamics CRM: Blogs 0 25.12.2008 15:05
Часовой пояс GMT +3, время: 13:30.
