Старый 11.02.2009, 11:05   #1
gatesasbait: Dynamics Ax 2009 SSRS report deployment under Server 2008
Источник: http://gatesasbait.spaces.live.com/B...B9F5!314.entry
If you get the following error in the deployment log file:
“Deployment failed with the following exception:
System.Runtime.InteropServices.COMException (0x80040208)
   at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
   at System.Management.ManagementObject.Initialize(Boolean getObject)
   at System.Management.ManagementBaseObject.get_Properties()
   at System.Management.ManagementBaseObject.GetPropertyValue(String propertyName)
   at Microsoft.Dynamics.Framework.Deployment.Reports.SrsWmi.get_ConfigPath()
   at Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployBusinessLogicAssemblies(IEnumerable`1 businessLogicAssemblies, DeploymentLogger logger)
   at Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.Deploy(IEnumerable`1 reportLibrariesToDeploy, IEnumerable`1 transitiveReferenceClosure, IEnumerable`1 cultures, DeploymentLogger logger, Func`2 connectionStringModifier)”
You just need to disable the UAC (User Account Control), or to run the Deployment tool with right-click “Run as administrator”. As it says in the Dynamics AX installation guide.
Duh…
gatesasbait: Dynamics Ax 2009 SSRS report deployment under Server 2008 (deux) Blog bot DAX Blogs 0 11.02.2009 23:05
jinx: Microsoft Dynamics AX 2009, Windows Server 2008 und SQL Server 2008 Blog bot DAX auf Deutsch 0 12.10.2008 20:10
gatesasbait: Dynamics AX 2009 Report Deployment error Blog bot DAX Blogs 0 17.07.2008 20:05
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Часовой пояс GMT +3, время: 20:04.
