Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 15.06.2009, 14:22   #1
Hugon is offline
Hugon
AX 4: Import from XPO - need help
Hi All
Do you know way how to import table's new fields and field groups ONLY from XPO file?
Hugon
AX Developer .::. Beginner
Старый 15.06.2009, 15:21   #2
You can use compare layers utility. This function is available in import dialog. Compare your USR with .XPO there. There you can open objects from the project from your USR and from .XPO in separate windows. For fields, field groups and groups on forms and reports it is convenient to use drag-&-drop from .XPO to your USR.
За это сообщение автора поблагодарили: Hugon (1).
Старый 15.06.2009, 17:33   #3
Hugon is offline
Hugon
Brilliant! I uploaded most of tables and forms using this way. But I have problem this doesn't work for EmplTable. I have SYS and BUS layers in EmplTable and I tried upload second one (BUS). Can't do this. Any ideas why?
Hugon
Старый 15.06.2009, 19:16   #4
What exactly the system does not allow you to do?
Старый 16.06.2009, 09:48   #5
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2156 (80) +++++++++
I can't drag table's fields and fieldgroups - is it correct? With forms it works fine.
P.S. I use not USR but VAR layer.
Ivanhoe as is..
Старый 19.06.2009, 18:24   #6
Hugon is offline
Hugon
I can't drag fields, field groups from EmplTable
Hugon
Старый 22.06.2009, 10:44   #7
anykey is offline
anykey
In DAX 4.0 it 's not possible to use drug&drop for table fields and field groups, but in DAX5.0 it's allowed for table fields (but not for field groups )
Старый 29.06.2009, 20:52   #8
Hugon is offline
Hugon
I can't agree with you :-)
I can drag&drop fields between tables from XPO and AX layer in DAX 4.0, ie. tables created by me and then when I am updating this table using import I can do this operation. For some reasons this doesn't work ie. for EmplTable.
Hugon
DynamicsAxSCM: Changes in Sales and Transfer Order Picking from Microsoft Dynamics AX 4.0 to Dynamics AX 2009 Blog bot DAX Blogs 0 18.05.2009 02:05
DynaMihamAX: Label import problem in Dynamics AX 4.0 Blog bot DAX Blogs 0 12.12.2008 13:05
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 12.04.2007 16:10
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 22.11.2006 15:20
Часовой пояс GMT +3, время: 08:12.
