#1 |
Microsoft Dynamics CRM Team Blog: Parsing Full Name Into Separate Name Fields
Источник: http://blogs.msdn.com/crm/archive/20...me-fields.aspx
============== Assume you are going to import Contacts into Microsoft Dynamics CRM using the Import Wizard. The file you are going to import has the Contact full name in 1 column. When attempting to import the Contacts using the Import Wizard you will receive...(read more) Источник: http://blogs.msdn.com/crm/archive/20...me-fields.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
