Старый 10.09.2009, 13:05   #1
palleagermark: Getting "Runas" back into your life
Источник: http://palleagermark.blogspot.com/20...your-life.html
When testing different uses scenarios on AX, I usually use "Run as..." to open a client as another user. That option is removed from a lot of programs in Windows 2008 (and Vista) and typically won't work on AX configuration files (axc).
I (or actually Google) found this tip on "Norm's PerformancePoint Server blog", on how to get RunAs back:
http://blogs.msdn.com/normbi/archive...dows-2008.aspx
За это сообщение автора поблагодарили: sukhanchik (1).
palleagermark: The book "Dynamics AX: A Guide to Microsoft Axapta" is available on Google Books Blog bot DAX Blogs 0 10.02.2009 15:05
Dynamics AX: ERP Live? "Software plus Services"? Blog bot DAX Blogs 0 22.04.2007 20:51
ALEG: Можно ли из "клиентского" решения сделать "тиражное" Blog bot DAX Blogs 0 16.11.2006 23:40
Галка "Закрыто" на таблице "В наличии" sev DAX: Функционал 1 11.04.2006 10:19
Часовой пояс GMT +3, время: 06:38.
