Старый 11.09.2009, 09:28   #1
Antant is offline
Antant
Ошибка при установке корпоративного портала ax2009, ошибка доступа
win2003x64, sql2008, ax2009sp1
При установке корпоративного портала на базе ax2009 происходит ошибка
   UpgradeEnterprisePortalSite
	  . (  HRESULT: 0x80070005 (E_ACCESSDENIED))
System.UnauthorizedAccessException
    Microsoft.SharePoint.SPGlobal.HandleUnauthorizedAccessException(UnauthorizedAccessException ex)
	    Microsoft.SharePoint.Library.SPRequest.OpenWeb(String bstrUrl, String& pbstrServerRelativeUrl, String& pbstrTitle, String& pbstrDescription, Guid& pguidID, String& pbstrRequestAccessEmail, UInt32& pwebVersion, Guid& pguidScopeId, UInt32& pnAuthorID, UInt32& pnLanguage, UInt32& pnLocale, UInt16& pnTimeZone, Boolean& bTime24, Int16& pnCollation, UInt32& pnCollationLCID, Int16& pnCalendarType, Int16& pnAdjustHijriDays, Int16& pnAltCalendarType, Boolean& pbShowWeeks, Int16& pnFirstWeekOfYear, UInt32& pnFirstDayOfWeek, Int16& pnWorkDays, Int16& pnWorkDayStartHour, Int16& pnWorkDayEndHour, Int16& pnMeetingCount, Int32& plFlags, Boolean& bConnectedToPortal, String& pbstrPortalUrl, String& pbstrPortalName, Int32& plWebTemplateId, Int16& pnProvisionConfig, String& pbstrDefaultTheme, String& pbstrDefaultThemeCSSUrl, String& pbstrAlternateCSSUrl, String& pbstrCustomizedCssFileList, String& pbstrCustomJSUrl, String& pbstrAlternateHeaderUrl, String& pbstrMasterUrl, String& pbstrCustomMasterUrl, String& pbstrSiteLogoUrl, String& pbstrSiteLogoDescription, Object& pvarUser, Boolean& pvarIsAuditor, UInt64& ppermMask, Boolean& bUserIsSiteAdmin, Boolean& bHasUniquePerm, Guid& pguidUserInfoListID, Guid& pguidUniqueNavParent, Int32& plSiteFlags, DateTime& pdtLastContentChange, DateTime& pdtLastSecurityChange, String& pbstrWelcomePage)
	    Microsoft.SharePoint.SPWeb.InitWeb()
	    Microsoft.SharePoint.SPWeb.get_WebTemplateId()
	    Microsoft.Dynamics.Framework.Deployment.Portal.EPSharepointAdmin.UpgradeEnterprisePortalSite(String siteUrl, String featureName)
	    Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.UpgradeSitesToDAX50(String virtualServerUrl)
:   . (  HRESULT: 0x80070005 (E_ACCESSDENIED))
Кто может подсказать, куда не хватает доступа? Перепробовал многое.
И почему никто меня не любит?
Да, я надоедливый
ax2009, sharepoint, корпоративный портал, ошибка, установка
Ошибка в логе при установке клиента AX 2009 sao DAX: Администрирование 9 04.02.2010 11:56
Ошибка при установке AOSа!!! nicko DAX: Администрирование 2 12.12.2005 15:50
Мастер настройки корпоративного портала выдаёт ошибку djoker DAX: Функционал 2 24.02.2005 05:32
где можно почитать о создании Корпоративного портала и его использовании alpin DAX: Функционал 2 26.12.2003 13:02
Часовой пояс GMT +3, время: 10:40.
