Старый 12.11.2009, 21:05   #1
paruvella: Using the Ax-Resource nodes as Metadata
Источник: http://paruvella.spaces.live.com/Blo...4DB0!275.entry
In this example, I am storing XML file as Resource under AOT of Dynamics Ax.
Also I am able to get back that resource as xml file, retrieving the file contents and use the same in our Business logic according to our needs.
In the same way we can use Resources as Metadata.
For a quick view of the new Resource node, see the following figure.
Find the related jobs at the following path, this path contains two jobs for
1)      Creation of new resource file.
2)      Reading the same resource as file.
http://cid-f2ec589e221a4db0.skydrive.live.com/self.aspx/.Public/Resource%20nodes%20as%20Metadata/Resource%20nodes%20as%20metadata%20xpos.zip
For this article I got basic inputs from one of my previous colleague Santosh blog and also from MS employee Dilip (DaxDilip) blog.
Thanks to both of you.
Dynamics AX: SQL Sever 2008 - Performance with Dynamics AX 2009 - Resource Governor Blog bot DAX Blogs 0 23.01.2009 22:05
Обсуждение документа "Сравнение 1С и AX" Кузнецов Александр Сравнение ERP-систем 44 20.02.2008 13:56
mfp: Microsoft Dynamics AX Developer Center: Your one-stop resource center for AX Development Blog bot DAX Blogs 0 14.06.2007 16:00
Часовой пояс GMT +3, время: 17:17.
